11-09-2018, 10:11 AM
#11 (permalink)
Moderator
Originally Posted by cRiPpLe_rOoStEr
It was developed when compact trucks were in fact somewhat compact, to the point that many modern compact cars are outsizing it, even the Prius. And it still has a lot of room for improvements to both aerodynamics and drivetrain.
The Ranger is still 15-20 inches longer than a current Civic, Corolla, or Elantra (or Prius), and almost exactly as wide (not to mention, quite a bit taller). The OP would be better off using that length to fit a tapering shell over the bed, and then put a cargo box extension on the end a la The Spirit of Ecomodder or that F-150 in Arkansas. Then fit panels to the underside to smooth all that out. Far less cost and hassle than trying to make it a hybrid, and he would end up with a quieter, more efficient road trip car with factory reliability.
11-09-2018, 01:39 PM
#12 (permalink)
I guess the possibility to use a camper shell might provide more comfort to sleep, plus it might still haul more camping gear than in a Prius.
You'd be quite comfortable with a tent, sleeping bag, and pad - which I've carried on my back or on a bicycle, and in motorcycle saddlebags across most of the US & Canada.
It was developed when compact trucks were in fact somewhat compact...
Compact, yes. However, while I've never driven a Ranger, if it's like theToyota, Dataun, Mitsubishi equivalents, it is NOT comfortable to sit in for long periods.
About the only reason I could see for using a truck is if you're planning to spend part of your time on roads where high clearance is needed. Which really isn't what I think of as "road trip".
11-09-2018, 06:05 PM
#13 (permalink)
That's what I was getting at by mentioning the Prius on steep rutted logging roads. The only way the Ranger can be the ultimate road trip vehicle is if ground clearance is a requirement for it being ultimate. Otherwise, it's kinda the opposite of that.
11-10-2018, 03:35 AM
#14 (permalink)
Your ranger fits my ideal for a camper/travel vehicle.
I would do as some have suggested and improve the aero as much as you can as that will give you the most economical returns for your time and money.
Then I would convert it to diesel. I have an old Mercedes OM601 four cylinder diesel I am looking to put into a compact pickup truck to putter around, with the wife, to camp and sight see.
Use of an older indirect injection diesel makes it easier to use the waste vegetable oil I have in a strategic reserve.
11-10-2018, 02:52 PM
#15 (permalink)
ScanGauge <3
In that position, I would convert the Ranger into dollars, and then convert the dollars into a small, efficient, but comfortable car for long drives. Do I lack imagination? Maybe.
Best tank (so far): 32 MPG
The Following 3 Users Say Thank You to ThermionicScott For This Useful Post:
11-11-2018, 03:20 AM
#16 (permalink)
Exactly. This thread was DOA.
11-11-2018, 04:46 AM
#17 (permalink)
I'm more used to the 2nd-gen S10 Blazer. An uncle used to own one, and I liked it.
11-11-2018, 01:55 PM
#18 (permalink)
Yes, and if ground clearance (and 4WD for the steep parts) is a requirement, you'd do better to start with an '80s Toyota pickup. I've sometimes wondered if the Prius powerplant could be mated to the pickup transmission without major problems.
11-12-2018, 11:54 PM
#19 (permalink)
Not so sure about the suitability of that, but the HSD system already had longitudinal-engine applications at least in the Lexus LS, Toyota Crown and those Hino 300 trucks.
