Old 06-21-2017, 09:24 PM   #111 (permalink)
The exhaust manifold is scorching hot about 20 seconds after starting.
Old 06-21-2017, 10:20 PM   #112 (permalink)
92 Civic VX since 2002
Magician's Avatar
Green Bean - '92 Honda Civic VX
90 day: 58.68 mpg (US)
Wife's Prius - '08 Toyota Prius Base 315K miles
Silverbullet - '08 Toyota Prius
It takes longer than 20 seconds to get extremely hot... try several minutes. Also the EGR valve doesn't provide all that much heat with a cold engine. The intake heater will provide very hot air even with a cold engine and it will provide it almost directly into the engine. The current set up has to first warm up the exhaust manifold, and while the engine is sucking this warmer air towards the intake through all of the tubing and filter housing... it also has to warm up that entire structure before it can deliver warm air into the intake manifold. Trust me, this takes several minutes to happen. I've concluded from testing the current set up that I will have a good sized gain from added a heating element just before the intake manifold. They already make such a device and I'll mod it to fit so I get almost instant hot air into my engine.
Old 06-22-2017, 12:59 AM   #113 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
If you are talking about the grid heater off a Cummins they are 200+A
The additional load from the alternator lugging will improve your %of load. The harder it works the faster it devlops heat.
Have you used an app or some sort of obd2 thing to monitor the Intake air temperatures. To find your target temperatures.?
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 06-22-2017, 06:02 AM   #114 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Interesting... seems the manufacturers are thinking along similar lines.
The Following 2 Users Say Thank You to teoman For This Useful Post:
Daox (06-23-2017), Magician (06-23-2017)
Old 06-22-2017, 10:13 AM   #115 (permalink)
Focused on MPG
Marinator - '06 Mercury Mariner Premier
90 day: 15.45 mpg (US)
SILVER BULLET - '19 DODGE GRAND CARAVAN GT
90 day: 19.73 mpg (US)
Myrtle - Wife's JKU - '12 Jeep JK Unlimited Sport
90 day: 16.07 mpg (US)
They cool the turbos with coolant to produce more power and get better emissions
Staying Focus'd on MPG
Old 06-22-2017, 11:35 AM   #116 (permalink)
teoman's Avatar
A3 - '12 Audi A3
He did mention faster engine warmup times.
Old 06-23-2017, 12:00 AM   #117 (permalink)
Magician's Avatar
I may have to reconsider the intake heater... but, my thinking was if I were to upgrade my battery to an AGM battery with a large amount of AMP hours... then I may be able to run something like that on Start-ups for about 5 minutes until engine is hot... Maybe not super high output heater, but maybe something that is a 500W or 1000W.
Old 06-23-2017, 04:19 AM   #118 (permalink)
Haven't seen any water-cooled exhaust yet, but it was usual in my country to have a heated intake manifold for dedicated-ethanol cars, and they also had a thermostatically-controlled valve to trim the intake air temperature and select the air from a hotter stream for a quicker warm-up.
Maybe you could eventually combine a water-cooled exhaust with a heater core at the intake side.
Old 06-23-2017, 06:32 AM   #119 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Try it at home in your garage with a hairdryer
Old 06-24-2017, 04:20 PM   #120 (permalink)
Magician's Avatar
Well, I just modified my warm air intake... probably a hot air
Intake now... I cut out a small section of the heat shield and formed my dryer vent tube so that it would suck air directly off the exhaust manifold. I'm thinking I'll get the warm/hot air quicker now and even higher temps. It should improve mpg as the more hot days have been great for mpg's regardless of it being very windy.
