Old 10-18-2016, 06:54 PM   #41 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Originally Posted by markweatherill View Post
Engine oil dilution? Solution: the 3000 mile oil change!
Using modern oils in modern cars a 3k oil change is a waste of money.
Old 10-18-2016, 06:55 PM   #42 (permalink)
All I see here is a few people complaining about how other people warm up their vehicles.
This is why I said that.
Old 10-19-2016, 12:29 PM   #43 (permalink)
Two weels Zero sparkplugs
Originally Posted by jamesqf View Post
But the heat from gasoline is free (if you warm up while driving, instead of idling), while a large fraction of the electricity you use for block heating is wasted, if your goal is simply a clear windshield.
But that isn't the goal, it is a nice added benefit but starting the car with the engine and oil already near operating temperature is the main goal.
Old 10-20-2016, 07:05 AM   #44 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
No, heat from gasoline isn't free if longer warm up time means more fuel is used (running longer in open loop, greater windage losses etc). That's without factoring in engine wear.
Old 10-20-2016, 07:25 PM   #45 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
This is why I'm looking at theas..
From:Eberspacher Hydronic II M12 12v (12kW) Heater Kit - HEATSO
But $1000 is spendy.
Many manufacturers are putting theas or part of this in vehicles. Fuel-driven heater, general description - V70 2007 - Volvo Cars Accessories
The advantages of a hydronic system is it can be plumbed to heat the oils. Self contained, isolated from engine coolant circuit. Heating can be achieved with a tube and fin trans cooler, P/S cooler for M/T and transfer case , ( dime a dozen at recking yards )aluminum foil taped to the bottom of the pan.add some foam more tape. Can be done without interfering with maintenance acces.
Found this wile looking for parts to build one from a propane Instant water heater , a set of check valves, aVw electric circulation pump. Add a remote from a set of Bling Bling leds from Autozone . And wala 15-30min from -40 to 160°f . No plug no problem. I was thinking add tubes in the oil pan and routing the exhaust from the heater, to warm the frosty oil . Till i build the oil pan I was thinkingof gust haveing the ehxsost blow out agenst the oilpan. Thoughts ? your pumping3ga of- 40 oil through your 4ga of 65°water it will take a while to warm all of the oil this is why I'll be idiling my cummins this winter wile pkuged in all the time. Last winter the stock 750w block heater wouldn't even melt the snow off the truck.
I idle till the grid heater cycle time comes down to just a pulse. In the cold, evan with plug and clear glass. Turn on the defrost turn down the temp. To put more load on the engine and warm the air around the radiator. My block off winter front is behind the A/C. So all the heat developed is concentrated on 120*2in aera of the radiator. I've put some thought into cause and effect.
What temperature can we warm mobile synthetic oil to without causing off gasing/boiling/ cokeing? VS conventional oil?
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 10-20-2016, 09:12 PM   #46 (permalink)
I made a 5,500 watt coolant heater for about $50.
http://ecomodder.com/forum/showthrea...9-a-32503.html
You just have to run the engine to circulate coolant (cuts defrost times more than in half) or plum in an electric coolant pump that circulates coolant without running the engine.
Don't try to heat the oil with exhaust. Heat coolant instead.
http://ecomodder.com/forum/showthrea...ger-29085.html
Xist (10-21-2016)
Old 10-21-2016, 05:45 PM   #47 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
Eliminating idle need
I've read your build, inspirational. The 5kw only helps when the frozen motor was running(can add a 12v pump @aproxamitly 125usd) and a has a 220v plug aka only works at home or .000005% of other places . That was fine when I lived in Washington/Portland. Now in Montana, having a failed cold start in the woods can be fatal. You are the one who inspired me to dive into setting up non plug-in pre heater as many community are off-grid. The 5kw block heater would require very expensive solor /battery upgrades , I live in town now but plans are in the works for moving to the country. Plan ahead...
Ordered this :
Eberspacher Hydronic D5WSC Water Heater 24v | eBay and a 12-24v dc-dc converter $500usd, with instalation kit. Aready have a battery isolator, I will be adding a 2nd battery to preserve the starting battery, and give self jump capabilities.
Started a new thread 5KW diesel fired block heater
Gumby Stay Flexible.
Former
87' Hyundai Excel
Old 10-29-2016, 02:27 AM   #48 (permalink)
nice post.
