Old 05-26-2021, 01:45 PM   #1 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Woodgas meetup 2021
I probably should have mentioned it before , but DriveonWood.com is having a meetup in Argos, IN June 3-6. I am attending as I've been curious about converting (even if it's just for curiosities sake) the mercury and it's ~2 hrs from me. If anyone has any questions I can try to find some answers. I've done some research so I might be able to answer basic questions already, but if not I can try to get better ones at the event.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 05-26-2021, 04:23 PM   #2 (permalink)
Wood pellets?
Particulate filters?
"We're deeply sorry." -- Pfizer
Old 05-26-2021, 05:06 PM   #3 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
Most of the forum users that run wood (vs charcoal) have a wood 'chunker' to turn it into cubes of a relatively consistent size. Converted pickups (don't have to have a compact setup) use wet hay in a barrel. The particulates stick in the water and when the engine is shutoff the water drains off the hay into a tank.
1995 Mercury Tracer
The Following User Says Thank You to M_a_t_t For This Useful Post:
freebeard (05-26-2021)
Old 05-26-2021, 06:22 PM   #4 (permalink)
This has me imagining George Poteet's '32 Ford bobber with an oak barrel in back.
https://daytonwirewheels.com/gallery..._1932_ford.php
Old 05-26-2021, 06:26 PM   #5 (permalink)
Wood gas is interesting to say the least, but nowadays I'd rather try it for stationary purposes as a replacement for LPG instead of resorting to it as a motor fuel.
Old 05-26-2021, 09:23 PM   #6 (permalink)
Growin a stash
How many mpt (miles per tree) do people get?
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
Old 05-27-2021, 01:55 AM   #7 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
They say 22 lbs of dry wood is about a gallon of gas. So... divide by 3, cube it, then take the square root...
¯\_(ツ)_/¯
I will try to get a general answer. Most like to convert the v8 dakota (90's I think) so I imagine most will be the same vehicle for a little more consistent data.
If this gives you any idea they are making sure to bring extra wood in case anyone who drove a far distance needs any for the return trip.
1995 Mercury Tracer
Old 05-27-2021, 01:56 AM   #8 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
Yea. Right now I'm mostly just curious. One of the members said I would get hooked, which is definitely possible, but I don't see it happening right now. Just having the know-how of building one could come in handy though.
1995 Mercury Tracer
Old 05-27-2021, 02:58 AM   #9 (permalink)
A gallon of gasoline has around 128,000 btu per pound.
A pound of dry wood has about 10,000 btu per pound.
But wood gas is supposed to be a lot less efficient than gasoline or propane.
Old 05-27-2021, 08:50 AM   #10 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
A gallon of gasoline is ~6lbs so that would be 20k BTUs per lb of gasoline vs 10k for wood (I didn't double check the BTU for wood)
1995 Mercury Tracer
