Old 06-01-2012, 05:44 AM   #1 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
Adding a VSS output to a Mechanical Speedo (reed switch)
Just made a quick search and maybe this link is helpful to people who only have mechanical speedo and want VSS output to mpguino...
Edit: some more stuff from same forum:
http://www.speedview.co/forum/Forum-Tech-Info
The Following 3 Users Say Thank You to meelis11 For This Useful Post:
AndrzejM (09-28-2012), lamb.chop (06-01-2012), Piwoslaw (06-01-2012)
Old 06-12-2012, 12:57 PM   #2 (permalink)
Peregrine - '95 Ford Aspire
90 day: 34.85 mpg (US)
Awesome find, I will need to do that when my unit arrives. I am guessing I won't need a converter board between the reed switch and the MPGuino, and that if I do, I can modify the source enough only need a simple one.
~Wild_Doogy
Edit:
I found that my speedo already has a reed switch so I just brought some wires off the back and hooked them up to my MPGuino. I am not sure where the error is, but I did notice an occasional error in my speed readout where my speed seemed to double, but that sounds like a double pulse.
