Old 03-19-2017, 04:52 PM   #1 (permalink)
aerodynamic car idea, a wild thought
This is a poor drawing of a design idea that I came up with which may be a more detailed design someday. But I'm not knowledgeable about aerodynamics or any field of engineering for that matter. So I'd appreciate it if you'd have any suggestions or opinions on the viability of such a concept. cheers...
The Following User Says Thank You to close circuit For This Useful Post:
aerohead (03-25-2017)
Old 03-19-2017, 05:58 PM   #2 (permalink)
Looks like a good start, just a few suggestions.
The area behind the rear wheel sweeps up too much, must be kept to about seven degrees or it may create lift.
Also try overlaying it with a 50 percent transparency of the aero-template as seen as a Sticky thread at the top of this forum.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 03-20-2017, 10:22 AM   #3 (permalink)
I've done these types of overlays maybe 100 times by now, just went ahead and did this one.
Some may disagree with the foil/wing option shown in pink. It's a idea which came up with an aerodynamist over coffee, but was told this cavity is best filled in to the recommended angle.
I just think it would look cool with a few diffuser/vane straighteners both vertical and horizontal. Although not the best in snow climates or on maintenance and cleaning. Might make good place for spiderwebs and bird nests too.
Chin Spoiler:
Roof Wing
aerohead (03-25-2017), BamZipPow (03-21-2017)
Old 03-20-2017, 11:17 AM   #4 (permalink)
Gaptooth - '00 Honda Insight
Gen-1 Insights
90 day: 58.91 mpg (US)
Such Fit - '07 Honda Fit Sport
90 day: 41.27 mpg (US)
The G1 Insight is somewhat close to that shape, though truncated. The rear wheels are significantly closer together than the fronts so the body can taper, and the body design really does work as is evidenced by some people exceeding 100mpg in it on the highway.
I've often thought it would've been neat had Honda extended the rear and made the space usable. It could almost certainly have been at least a 3 seater.
Old 03-20-2017, 11:22 AM   #5 (permalink)
wow it's marvelous what this tool is capable of, I wanted to try as you suggested but couldn't work with it on mobile device. I'll try drawing some alternative designs based on this. I think the rear end could be a vertical line instead of a pointy apex, sort of like the wing as recommended. and the front end could be a more aerodynamic bubbly oval area instead of the the plane-like nose which albeit looks cooler imo.
Old 03-20-2017, 11:41 AM   #6 (permalink)
Are you trying to design a 5-seater with a mid-mounted cockpit? That looks interesting.
Old 03-20-2017, 11:51 AM   #7 (permalink)
Originally Posted by close circuit View Post
I think the rear end can be a vertical line instead of a pointy apex, sort of like the wing it recommends.
Draw a rear view accommodating both US and European sized license plates, and include plate lighting and really important; a rear bumper and tail lights.
The real reason the rear diffuser with wing/foil is wrong minded is rear impact.
In a perfect world or on a race car it would work well enough, but is complex and would take a lot of wind tunnel testing to get right.
EDIT:
I just spotted this inverse and sort of boxed out rear diffuser - almost a mirror image of most, a male/female mold.
http://honda-tech.com/forums/honda-c...build-2563960/
Maybe there is fun research ahead for this part of the car.
Chin Spoiler:
Roof Wing
Old 03-20-2017, 12:54 PM   #8 (permalink)
yes that's exactly what I'm thinking of. front row of three and rear row of 2 so it'll fit in water drop streamline.
Old 03-20-2017, 01:08 PM   #9 (permalink)
EDIT:
I know the regulations won't allow such a concept to be street legal, that includes tail lights, license plate, pedestrian safety etc. as you mentioned. but that wouldn't keep me from going for a detailed design especially if I had the access to a 3d software and a clay modeling platform. also I think this round body allows for a chassis consisting of intersecting uninterrupted elliptical lines. that could provide a safe life zone for the passengers. I imagine elliptical structure would give rigidity and strength.
Old 03-20-2017, 01:58 PM   #10 (permalink)
I know the regulations won't allow such a concept to be street legal...........
With my own design exercises I find that adding those little details an advantage that helps mature it.
The more details you address such as; engine access, wiper blades, air intakes/exhaust ventilation, interior design, chassis structure, buildability, headlights, turn signals, side view mirrors, door handles, gas cap, gas tank location...................the more detail addressed, the more thought out and realistic it is, and perhaps the more appreciated by the viewer.
Imagine some perspective client or employer looking at your drawing for five minutes without saying a word and then suddenly they say how do you get in the trunk? Without the little seams and joints providing clues the question could come up.
And yes; that rear hatch opening just as the door opening size and shape is going to affect crash safety. You don't have to do crash safety simulations as the general designer or stylist but you don't want to raise any read flags and look impractical.
Now if you were in a design competition sponsored by some Tier-1 supplier that just invented some super material which would allow you to do things never before possible, that is a different opportunity and a different expression of design to solve or exploit and something different would emerge.
Chin Spoiler:
Roof Wing
aerodynamic car, streamlined car, three wheeler
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
