Old 12-23-2013, 07:24 PM   #1 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Antenna delete blanking
Minor mod completion:
I decided that two-and-a-half years with black duct tape over the whole where the antenna used to emerge from the A Pillar is enough. I had thought I wanted to bondo and paint, but I want a more reversible solution, since I want to consider this as a way to wire in roof-mounted solar panels one day (if I ever do it).
So, I cleaned the old tape gunk off with "Goof-Off", took apart the OEM plastic fitting and cut some sheet aluminum to fit the hard rubber bottom grommet piece, drilled holes in the aluminum sheet for the OEM screws in the original spots, and plasti-dipped the whole unit with three layers to help seal it up. Lastly, clear silicone indoor/outdoor caulk around the out edge. Here it is, process and result. I'm confident it'll be water tight for years. There is also a layer of aluminum tape under the rubber grommet (can't see it, of course). PICS:
james
ID:	14281   Click image for larger version
ID:	14282   Click image for larger version
ID:	14283   Click image for larger version
ID:	14284   Click image for larger version
Last edited by California98Civic; 12-24-2013 at 05:31 PM.. Reason: added link to my original delete post from May 2011
Old 12-23-2013, 07:56 PM   #2 (permalink)
90 day: 29.78 mpg (US)
Looks great!
I wonder why more manufactures don't choose to use glass-integrated antennas? My TSX has a glass-integrated antenna, but I noticed the Prius does not. Strange that a car striving for the best fuel economy and most streamlined shape would put one of those ugly stubbies on the roof. Perhaps the rear glass is too sloped on the Prius to get decent reception from an integrated antenna?
California98Civic (12-24-2013)
Old 12-24-2013, 05:37 PM   #3 (permalink)
Cyborg ECU
Thanks redpoint5! Happy holiday!
Old 12-24-2013, 09:56 PM   #4 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
It definitely looks good! Is there anyway to make it more flush with the body?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 12-24-2013, 11:37 PM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Personally, I'd bondo the hole in the OEM plate, spray it black and it would look original. You could also sand it down a bit to reduce it's profile.
