Old 03-19-2008, 02:35 PM   #1 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Any guesses on '83 Civic mpg?
About a year ago I picked up a '83 Civic dx 1.5L hatchback with a bad transmission, found a transmission from a '83 civic FE.
The Honda Civic FE had a 1300cc engine with peek torque of 68 ft.lbs @ 4,000rpm, Civic DX's engine is 1500cc with 77 ft. lbs @ 3,000rpm, my figures show that with the FE tranny my 60mph 5th gear engine speed should then drop from 2,500rpm to 2,200rpm, other then the higher geared tranny, the Civic Hatchback FE would have things like an additional fuel cut off solenoid on it, and the fuel cut off kicks in at lower engine speeds while coasting in gear, the ignition timing is the same, valves open and close at the same crank rotation, carburetors have the same venturi openings altho they have different model numbers, I think just different jets, but over all they didn't seem to be drastically different, the DX weighs only 84 pounds more then the FE, so a total of 1,867 pounds curb weight, with a 1500cc engine that puts out 63hp@5,000rpm (compare to 60hp@5,500 of the 1.3L FE) and seats 5 where the FE only had seat belts for 4.
So as soon as I can get this car out of the shed (mud, snow is in the way) and get new tires on it I plan to start using it, if mileage good enough, and if I like how the car feels I'm thinking I might sell the VX, this cvcc car has almost no rust, and fewer miles, but is also 9 years older, only reason for not doing that is that I don't want to drive the cvcc in the salt.
Old 03-19-2008, 02:35 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I'll throw down a guess of 37 mpg,
Old 03-19-2008, 02:53 PM   #3 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
The way you drive? 33.7mpg.
Old 06-28-2008, 12:54 PM   #4 (permalink)
Ryland's Avatar
well, after it's sat for almost a year and a half with very little use I filled up the tank and started to drive this car, first tank was 39.5mpg, 60 miles of that was with 4 people in the car the rest as just around town, just driving like normal, took about 100 miles before it started to smooth out and run better, 2nd tank looks like it might be better mileage, I'll know in a few weeks.
Old 06-30-2008, 06:54 PM   #5 (permalink)
EcoModding Newbie
Parachute - '03 Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Neon Highline baby!
90 day: 31.39 mpg (US)
Hi Ryland,
I am very interested in how your car does. I have access to a 78 CVCC Accord that needs a bit of work but ran well the last time it was used. I went to 3geez - Powered by vBulletin and they reported around 30mpg is common with these cars driven normally. One person posted they get around 39mpg doing mostly highway.
I am trying to decide if its worth fixing and licensing based on MPG. It would be a fun car but I'm not sure if it can beat my neon significantly.
Ian
Old 07-01-2008, 04:24 AM   #6 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ranchero GT
Spaz - '83 S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
EPA Est
EPA est on the 85 1.3 were 32 city 38 hwy
Honda...the economical, renewable resource.
Old 07-12-2008, 05:32 PM   #7 (permalink)
3rdgencivic's Avatar
Big Heavy Pig - '91 Integra GS
90 day: 32.88 mpg (US)
Rusty - '87 Civic Si
90 day: 34.64 mpg (US)
The "1500" (1488cc) EM CVCC motor was rated at 34 City/47 Hwy. I'm guessing with the taller gearing of the 1300 trans., you could do even better than that (and look cool doing it) The "FE" was rated at 41/55.
IIRC, the EW, even the 1.3, was a different animal from the from the 2nd gen EM motors.
Old 07-12-2008, 10:40 PM   #8 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
I had a '78 Hondamatic that delivered 30mpg in spite of a fuel pump leak. I drove it like a man possessed; I'm certain you can do better.
You're not in front of me...
I'm 25,000 miles in front of you.
EM Sticker contest #2: guess Mom's MPG! ('97 Camry 4-cyl auto) ends Sun., Feb. 3 MetroMPG Hypermiling / EcoDriver's Ed 33 02-04-2008 10:30 PM
2004 Honda Civic Sandy Introductions 4 01-22-2008 12:57 PM
Equivalent MPG of cycling - garage feature? MetroMPG Alternative Transportation 21 12-27-2007 02:57 AM
Article: 57 mpg? That's so 20 years ago SVOboy General Efficiency Discussion 17 12-23-2007 10:56 PM
Finally: 100 mpg (US) round trip in the Blackfly - new and improved: 133 mpg MetroMPG Hypermiling / EcoDriver's Ed 3 11-28-2007 03:23 PM
