Old 08-05-2008, 02:01 PM   #11 (permalink)
EcoModding Dilatant
Volvo - '00 V70 XC AWD SE
90 day: 27.7 mpg (US)
Originally Posted by MazdaMatt View Post
Hmm... wonder if my 94 F350 7.3L Deisel is OBDII... doubt it.
I think OBDII started in 1996. Of course MY diesel is 1995. Diesels also have a problem with electronic fuel monitoring systems since they recirculate fuel to the tank, so most gauges like this don't work even with OBDII.
Old 08-05-2008, 02:02 PM   #12 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
hmmm... maybe that's just the motivation that I need to clean the basement.
Old 08-05-2008, 02:03 PM   #13 (permalink)
Thanks for the info. It would be nice to get some of the other data to see if there is something wrong with my truck, or if it just sucks.
Old 08-05-2008, 02:06 PM   #14 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
A vacuum gauge is better than nothing -- should work on diesels.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 08-05-2008, 02:07 PM   #15 (permalink)
EcoModding Dilatant
Question about ScanGauge II:
I looked at the ad, but it didn't have a lot of information. Does SGII do more than mileage and trip calculations? Does it read OBDII error codes? My Volvo already has a factory trip/mileage computer, but if the SGII does more than just duplicate it's functions, I DO need an OBDII code reader.
Old 08-05-2008, 02:09 PM   #16 (permalink)
EcoModding Dilatant
Nope, diesels don't use vacuum either. They're weird, but I love 'em.
Old 08-05-2008, 02:10 PM   #17 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
I looked at the ad, but it didn't have a lot of information. Does SGII do more than mileage and trip calculations? Does it read OBDII error codes? My Volvo already has a factory trip/mileage computer, but if the SGII does more than just duplicate it's functions...
Yes to error codes. It has more gauges than just those two but I like the SG because it can also show me the GPH, coolant temp, intake air, voltage, and digital readouts for MPH, RPM plus trip and tank info -- armed with that info, I can make mods and see if they're really worth my time or not.
EDIT:
Ah, my bad on vacuum then.
  • driving style
  • aerodynamics
  • tires
  • weight reduction
Old 08-05-2008, 02:39 PM   #18 (permalink)
Moderator
Daox's Paseo - '97 Paseo
90 day: 67.16 mpg (US)
Daox's Prius - '04 Prius
90 day: 52.66 mpg (US)
The scangauge can give you feedback on almost every sensor in the engine.
EcoRenovator.org - Efficient living and green home improvement
Prius Build Thread
Paseo Build Thread
Old 08-05-2008, 05:28 PM   #19 (permalink)
Red Egg - '95 Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
I had the sgI in my neon, then got a performance version by another company that fit in a 52mm pod. whatever you choose they are so worth it. You can take them along in any car. You are by no means "stuck" with this product ever.
Old 08-07-2008, 02:29 AM   #20 (permalink)
NRG SVR
smartzuuk's Avatar
I can't keep them in stock...
Scangauge II: ecomodder pricing in effect now!
Best mileage to date: 2.23 L/100km - 105 mpg (US) - 126 mpg (imp)
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
ScanGauge Canada DavidH Instrumentation 3 08-29-2008 01:44 PM
Scangauge II vs cruise control rjacob Instrumentation 4 06-30-2008 09:57 AM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 04:26 PM
scangauge coolant temp accuracy? Daox Instrumentation 12 05-03-2008 02:09 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
