Old 01-13-2010, 01:45 PM   #1 (permalink)
90 day: 51.82 mpg (US)
Automotive X-Prize: "The Very Light Car" (also very aero) with conventional engine
Alerted to this via ABG:
(You know you're an EcoModder when you show the rear view first )
The company, Edison2, is located in Lynchburg, Virginia, and ruled out an EV drivetrain primarily due to the weight of batteries.
We don't have any details on the weight or CdA, but they're dealing with an order of magnitude change in some areas on the weight side of things:
Every component of the Very Light Car has been evaluated for function and redesigned with an eye to simplicity, strength and low weight. Brakes that normally weigh 10 lbs are less than a pound; lug nuts 0.2 oz instead of 2 oz. - source
Here's the drivetrain. Anyone recognize it? Looks to me like it may be a motorbike engine:
Source: Edison2: The Very Light Car (X PRIZE Contender) - Gallery - The Very LightCar
Space frame:
Unfinished body shell:
ABG called it a "poor man's Aptera". Not very nice! (Probably not true, either.) Coincidentally, there's an Aptera in the left side of the above photo.
Web site: Edison2: The Very Light Car (X PRIZE Contender) - The Very Light Car
Name:	_AAA early engine simple but good.jpg
ID:	5377   Click image for larger version
Name:	_AAA oliveratspeed_low.jpg
ID:	5378   Click image for larger version
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (02-10-2010), dcb (01-13-2010)
Old 01-13-2010, 02:36 PM   #2 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
i want it.
single person car thread
Old 01-13-2010, 02:51 PM   #3 (permalink)
Edison2 Very Light Car
Hi Darin,
Ya beat me to it:
This car has come a long way since the last one we saw -- it is very similar to the Aptera 2e in some obvious ways, and it quite different in other ways.
(click on picture for link)
The similarities are: streamlined body with outrigger wheels, and two seats side-by-side, composite construction.
The main differences are: ICE-only power train, 4 wheels, 1 entry door.
I like parts of this, but others are a bit odd. So, what do you think?
Old 01-13-2010, 02:53 PM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Nice, aero, small engine, it should be able to do a long hiway trip more efficiently than any hybrid. Low weight might make it competitive in the city too.
Old 01-13-2010, 02:59 PM   #5 (permalink)
epic stock master
luvit's Avatar
does the driver door swing up like a delorean? ..or like a lamborghini?
Old 01-13-2010, 03:06 PM   #6 (permalink)
I was wondering how they made the suspension work within those fixed aero struts -- here's what appears to be the rear suspension:
The shock sits closer to the car, and the top is braced on the chassis. I guess that there are two large diameter bearings on the inner end, and the whole tube rotates as the wheel moves up and down? They seem to not be showing the outer swing arm? This set up bothers me -- there must be a lot of torque and bending on this tube...
And I also like the "very light wheels":
Darin, that engine certainly looks unique -- there is a heck of a lot of plumbing! It also looks to be a turbocharged 2-stroke?
Old 01-13-2010, 03:07 PM   #7 (permalink)
Not sure about the door. Might check their gallery: Edison2: The Very Light Car (X PRIZE Contender) - Gallery - The Very LightCar
One thing I noticed: doesn't seem to have any (conventional) suspension.
Old 01-13-2010, 03:38 PM   #8 (permalink)
They are not revealing the key spec: how much does it weigh?
Old 01-13-2010, 04:06 PM   #9 (permalink)
It has an extra wheel.
Old 01-13-2010, 04:12 PM   #10 (permalink)
dcb
needs more cowbell
dcb's Avatar
lol, it has two extra wheels for that matter, but I still like it
where's the tow hitch?
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Automotive X Prize - would a modded Civic VX make it? Krieg EcoModding Central 31 01-02-2008 07:06 AM
