Old 11-04-2012, 10:12 PM   #31 (permalink)
spyder - '00 MR2 Spyder
House of Tudor
90 day: 31.43 mpg (US)
That's right, 8x the power for 2x the speed. That's why on the track, while a huge amount of energy is lost to braking, probably a bigger amount of energy is lost to pushing the car through the air at high speeds, which is why the brakes aren't being cooked with anywhere near the full output of the engine. It's why you need only 300-400hp in a "typical" sports car to hit 180mph, but to hit 250mph you need over 1000hp.
Old 11-04-2012, 10:45 PM   #32 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
Kia - '06 Sportage EX
90 day: 23.63 mpg (US)
Originally Posted by GRU View Post
I have driven my car on the same road. At the same speed. At the same time ( reseting the trip mpg every 2 minutes ) and got different numbers every time because its almost impossible to have the same exact conditions even if they are only 2 minutes apart
Ok......
So the solution is to do nothing?
sure there are variables but the idea is to get a BASE idea of what the car does.
1. warm it up before first drive.
2. do it after noon (temp stay consistant for a couple of hours)
3. Up and down negates wind
4. don't do it on a windy day.
5. do it on a day over 70 degrees.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 11-12-2012, 01:20 AM   #33 (permalink)
Camron - '99 Camry LE
90 day: 27.07 mpg (US)
Wow! Talk about a response. Yes this is my Eco car, mainly because its just the car I have right now but it holds it own at 40mpg cruising
On that trip I talked about there is a lot of up and down and I coasted in neutral down some big hills which really boosted my mpg
I will do some A B A testing and let you guys know what I find and see if I can find the engine load gauge
Thanks for all the help guys!!
Old 12-18-2012, 12:30 AM   #34 (permalink)
ron
double eagles - '99 ram slt
90 day: 19.48 mpg (US)
ok all I am going to test the speed verses mpg quandry this weekend and will post the results. my last trip of 200+ miles one way yielded unexpected results. at 1950-2000 rpm mileage was mid 20s . I increased the speed to make my grandsons soccer game to 68-70mph and I had a mileage jump a big jump 6-8mpg at 2400rpm. I suspect the turbo sweet spot. I am going to try it again and will keep all informed
Old 12-18-2012, 12:46 AM   #35 (permalink)
Blackfly - '98 Metro
Last 3: 70.78 mpg (US)
ForkenSwift - '92 Metro EV
Last 3: 95.68 mpg (US)
U.F.O. - '00 Insight
Last 3: 92.09 mpg (US)
You probably already know this, but measurements taken during a trip aren't the best way to do this.
You ideally want to: repeatedly drive the same segment of road one run after the other, in the same conditions, with a fully warmed up vehicle, changing only your speed on each run.
That's how to get the most credible figures/results. Minimize the number of variables that could be affecting your fuel consumption to just one: speed.
Latest project:Honda Insight boat tail extension (cardboard) tuft video; ABA test +9.7% Latest test: 2000 Insight: +14% MPG @ 80 km/h with 5 easy aeromods (ABA)
mcrews (12-18-2012)
Old 12-18-2012, 10:08 AM   #36 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
Drag is a second-order function of velocity.
...but,
Power is a third-order function of velocity.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
The Following User Says Thank You to Old Tele man For This Useful Post:
Mustang Dave (12-18-2012)
Old 12-18-2012, 08:33 PM   #37 (permalink)
ron
well I hope that I have found the point where all mechanicals are at their most efficient and I am using the fuel not wasting it at a lower speed. I am going to top the tank and drive by the scangauge for max mileage then when I exit the freeway I will top it off again and see the result, I already know that stop and go in L.A. is a fuel suck. Its worth a check .
Old 12-23-2012, 08:11 PM   #38 (permalink)
ron
OK here it is we just got back from huntington beach .down to H.B. 304.4 miles 16.621 gal mixed driving 18.314 mpg running 67-68 mph. return trip home to S.L.O. ca 224.5 miles 10.149 gal all freeway 60 mph 22.12 mpg. see fuel log. bottom line is speed kills/stop and go is bad for mpg
Old 12-24-2012, 08:37 AM   #39 (permalink)
Intrepid3.2 - '00 Intrepid ES
Team Dodge
90 day: 23.97 mpg (US)
Pacifica3.5AWD - '04 Pacifica Touring
Team Dodge
90 day: 20.74 mpg (US)
We don't notice air as having resistance really because we are accustomed to it, but it can be treated like any fluid. The faster you go the more you compress the air and the more it wants to act like a solid.
camry
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
