Old 11-08-2009, 08:14 PM   #1 (permalink)
OBDuino coder
Magister's Avatar
Titine - '07 Elantra GL
Thumbs up Blocked my lower grille today
on my Elantra HD, with a piece of black foamboard and 6 black tie-wraps.
I put it behind the grille so it's almost invisible, the coolant temp is almost the same, about 87°C and it's about 15°C outside today, so in winter at -20°C I think it will help to keep my engine warm.
Old 11-09-2009, 01:14 AM   #2 (permalink)
recession proof rebel
k.civic.f4i's Avatar
nice. if you can, try to make one thats flush with the bumper
Old 11-09-2009, 06:12 PM   #3 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Yes, it would be a little more aerodynamic to have a smooth bumper, but what you have now is a stealth aeromod that doesn't impact the appearance of the car at all. Nice work. I bet you can leave it installed year round.
Old 11-10-2009, 10:13 AM   #4 (permalink)
OBDuino coder
Magister's Avatar
A member here already did it
Tas's 2008 Elantra Build Thread
But I don't like the look, and I'm not sure it makes a difference, once the air is compressed in the hole, the coming air just slide on it I think, it should be simulated on a computer!
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/blocked-my-lower-grille-today-10920.html
Posted By For Type Date
EcoModder.com Latest Blog Posts This thread Refback 11-11-2009 09:43 PM
blocked grille tonite... mcrews Aerodynamics 19 01-30-2012 11:30 PM
What do you guys think about a grill block behind the grill? dremd Aerodynamics 7 02-02-2009 03:03 PM
Temperature controlled grille block Piwoslaw Aerodynamics 19 11-09-2008 11:24 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 11:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 11:14 AM
