Old 08-01-2010, 02:19 AM   #1 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Smile Cab to camper shell gap...
Not sure how much it will increase/decrease the aerodynamics of the truck/shell...but I put some wall baseboard/cove to cover up the gap. Got three 4' strips and ended up cutting the side ones down so it would look "normal". Cost fer the three strips was about $10.
Got tired of dealing with the water running in between there when it's raining...making it harder to see out the back than it needs to. I'm using this as a primary method to reduce the amount of water dropping back there...kinda like an umbrella. I only have it attached to the cab as the bed/shell will flex some as I'm driving down the road due to bumps and twists in the road. If I were to attach it to both the cab and the shell...it would have a tendency to rip one or both sides out and cause it to leak or fall off (eventually).
I tried this with my old 1993 T-100 with the 8' bed and a camper shell but with clear packing tape. The UV rays beat up that tape after about 2 weeks so I would have to re-tape more often. I tried various adhesives...but those didn't hold up at all.
So this time around with my new 1998 T-100 xtra cab with a 6.5' bed and a camper shell, I decided to give it another shot.
I tried clear shelf liner but as the UV rays hit it...it got weaker and only lasted a couple days before tearing/blowing out.
With my current camper shell, I had to cover up the top of the cutout fer the 3rd brake so the baseboard doesn't cave in that gap and also added some coroplast support under the bottom. I might eventually clean up the gap cover so it's cleaner without the small hump. Might make it easier to git a better seal from water leakage.
I ended up gitting some 2" wide (6 mil thick) vinyl tape from Identi-Tape.com. The tape will allow me to easily pull the gap cover if I need to.
I guess this will act some what like a trip strip...
I won't be able to collect any long distance data until I make my run out to the LA area.
Piccies!!
Side view...
Top/side view...
Top rear view...
Old 08-01-2010, 03:22 AM   #2 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Cherokee
90 day: 15.66 mpg (US)
ZX7R Ninja - '99 ZX7R Ninja
90 day: 42.45 mpg (US)
Kill two birds with one stone, I like it
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 08-01-2010, 08:18 AM   #3 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
Looks good, professional job.
Nissan Versa Aeromods
Civic VX & CX Spark Plug Gap flydude1221 EcoModding Central 8 05-06-2011 10:17 PM
Shell claims new "FuelSave" gasoline formulation increases fuel economy MetroMPG General Efficiency Discussion 32 11-07-2010 06:12 AM
Does a traditional square pickup camper shell topper help or hurt drag & mileage? bondo Aerodynamics 49 02-01-2010 01:24 PM
Smoothing the gap between pickup cab and bed fourfa Aerodynamics 20 01-28-2010 12:49 AM
Nitrogen Enriched Fuel by Shell trikkonceptz The Lounge 22 04-14-2009 05:05 PM
