Old 11-17-2009, 02:57 PM   #151 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 64.74 mpg (US)
Here is my current front bumber setup.
Principle is the same as in basjoos nose...
http://cid-acb1f13bac776768.skydrive...MG%5E_6979.jpg
http://cid-acb1f13bac776768.skydrive...MG%5E_6974.jpg
It took almost 30 hours to get bumber to this stage but its not ready yet.
Future plans is to make air ducting system through the hood like in race cars. Intercooler would be before the radiator and after that straigth outlet through bonnet.
More photos of the bumber and the whole car:
seatti - Windows Live
Old 11-18-2009, 07:53 PM   #152 (permalink)
nose
IMG_6979.jpg - Windows Live
IMG_6974.jpg - Windows Live
I like it,but don't be disappointed if it doesn't spin your head at the gas pump.I believe you will see only modest gain at best.
Old 11-30-2009, 02:48 PM   #153 (permalink)
Vekke's Avatar
Diesel
First full tank results:
front bumber gain is 2-3 MPG. You can see the results also in my coast down tests. I have only done two coasts with new bumber and weather have not been the best. I will tell the results when I get more data...
If aerohead thinks thats shape is not the best, but maybe the gains come from smaller cooling openings.
Old 11-30-2009, 03:32 PM   #154 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
bumper.
Old 11-30-2009, 06:24 PM   #155 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
Nit-Picker.
But seriously, Franks is right, it is BUMPER. Otherwise this thread is going to turn into a BUMMER.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 11-30-2009, 06:48 PM   #156 (permalink)
results
Automotive engineers would be required to perform immediate back-to-back coastdown tests ( 10 coastdowns with,10 coastdowns without ) on the same day,same track,and no significant weather changes.
This is one reason they've gone to wind tunnels,as they can "control" the "weather" inside.
Outdoor testing is very problematic,requiring extremely sensitive measuring equipment or long-distance testing compared to a representative baseline.
Any change to temperature or barometric pressure can skew results right off the charts.
The "racing" nose on my Honda allowed only a 0.5 mph increase to top speed in the 100-mph region.It would not have shown up at the gas pump.
Old 12-01-2009, 12:49 AM   #157 (permalink)
Yep, gettin' started...
ECONORAM - '07 RAM 1500 QC SLT flex-fuel
90 day: 17.82 mpg (US)
the Avenger - '08 Avenger SXT
Last 3: 27.18 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by aspera View Post
Do you really need a ramp or can you just use a huge splitter? This is one of the biggest around. It's all carbon, but the underside is what's cool. The underside is all foam. They put lots of foam under there and the stuff that hangs too low just gets worn away. The result is exactly the correct ground clearance. No math, no guessing.
That is a good idea. GE does the same thing with the sealing surfaces inside the engine where the fan and compressor blades rub. The material is abraidable (spelling?), so only as much as needs to gets worn away. Presto, perfect seal!
Old 12-02-2009, 02:30 PM   #158 (permalink)
Stickers - '91 Tempo GL
Send a message via AIM to Hermie Send a message via MSN to Hermie Send a message via Yahoo to Hermie
That looks like a Pikes Peak racer to me. TONS of front downforce on those babies!
If I can get my hand on a fiberglass/carbon fiber hood for a Ford Tempo, I could probably make more aerodynamic hood vents similar to that there.
For my car, I've decided to forgo the blunt air-dammed front end and have a smooth skid-plate-like coroplast pan under the bumper, remove the horizontal stock air dam, and set the end of the coroplast low enough to get the lowest part out of the immediate airstream. I'm also going to be making a small splitter lip to help with reducing lift.
Old 12-02-2009, 08:46 PM   #159 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
Old 12-02-2009, 10:39 PM   #160 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Frank you ******* !
Hermie, why are you so concerned with lift on your car ?
mods-data-% change or Cd change ( installment#4-Rooflines( quotes)) ) aerohead Aerodynamics 0 05-24-2008 03:49 PM
