Old 06-14-2018, 03:38 PM   #1 (permalink)
Cetane Booster - lubricity issues?
Been using Millers eco-boost for the past few tanks - started at a single dose, saw some improvements then upped it to a double dose as directed on the bottle - better still.
I've now ran out of Millers, so ordered some 2EHN as it's about half the cost, and I'm intending to keep going with the double dose.
My understanding is that 2EHN is what actually boosts the Cetane, then Miller's (or whoever) add their own fillers, detergents, whatever.
So if I switch to just 2EHN is there any risk? Reduced lubricity from adding 2EHN is my main concern.
Thanks,
Chris
Old 06-15-2018, 01:33 AM   #2 (permalink)
Dark Egg - '12 VW Touraeg
I was just reading about all the low sulfur diesel fuels and additives today. I was adding power service which is available everywhere diesel is here but now I think I may stop and just use what the refinery is delivering to the pump. I don't know, I want to believe additives do something but I don't see any real laboratory type testing showing they do. My biggest concern is the very expensive common rail injectors but at about $15 per 1000 miles for the additives they would have to add about 100,000 extra miles just to break even. I'm just on the fence.
Old 06-15-2018, 01:51 AM   #3 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
I have over 300,000 miles on my 91.5 with PS gray in every tank1oz/3ga. lubricity is a known issue with these VE pumps were designed for the normal sulfur content. So if lubricity is an issue with the common rail use a lubricity agent
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 06-15-2018, 02:14 AM   #4 (permalink)
I run waste motor oil in the tank from time to time. Seems to run smoother that way. I wouldn't buy any additive as the cost would likely not be offset by the reduced wear.
Old 06-15-2018, 08:58 AM   #5 (permalink)
Thanks guys, I'll just stick with the 2EHN then, and not worry about it. As far as I'm aware there's no big lubricity issue with the 1.4tdi engine.
Old 06-15-2018, 10:33 AM   #6 (permalink)
This is what I always hear from the owners groups but from laboratory tests and info from the refineries, even though they remove some of the lubricity with the sulfur they add that back with a lubricity enhancer right at the refinery. Supposedly there is just no need to then add more yourself at the pump. There is a chart going around but I question it because it is really old and the starting numbers they provide for the pump diesel are nowhere near what is required by law in the US and most everywhere else. Basically it seems they made up some diesel with very poor properties that wouldn't be what you get at your local station. I was going to start adding two stroke oil.
My gut would go with what the huge trucking companies do, if it provides a cost benefit they would use something although maybe not if it caused emission increases. I don't think they add anything.
