05-18-2011, 04:24 PM
Chevrolet Cruze ECO "returnless" variable pressure fuel pump
GM is promoting the crud out of the Cruze ECO these days, with gas prices being near record highs.
Just spotted this tidbit about the car's variable pressure fuel pump, which does away with the need for a fuel return, and reduces load on the engine (through reduced electrical demand):
The microprocessor behind the Electronic Returnless Fuel System electronically manages the delivery of fuel from the fuel tank to the engine. It is controlled by the brain of the Cruze’s fuel system – the fuel system/chassis control module. The control module can raise or lower the pressure in the fuel line by speeding up or slowing down the fuel pump. This allows the system to make more efficient decisions on the amount of fuel provided to the engine compared to vehicles with a standard fuel system whose fuel pump runs at full speed all the time.
The system reduces voltage to a point where the pump doesn’t deliver excess fuel. The lower fuel pump speed results in less power consumption, which reduces the electrical load on the alternator. That reduces the strain on the engine, resulting in increased fuel efficiency.
source: GM - Canada - News & Information
Neato.
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
05-18-2011, 07:08 PM
...beats walking...
...they're also touting their Regulated Voltage Control (RVC) system that is effectively an "on-demand only" field regulator system that holds battery voltage at ~ 12.3VDC instead of 14.7VDC all the time.
...instead, it only pumps the voltage up to 14.7VDC right after a heavy load (starting) then backs off to ~12.3VDC while cruising; but, goes back UP in alternator output voltage (if needed) during decelerations and breakings.
...good news for lamps and light bulbs, but not so good on batterys themselves.
The Following 2 Users Say Thank You to Old Tele man For This Useful Post:
05-18-2011, 08:47 PM
Look under the hood of any Ford Focus made in the last 5 or so years and you will see a return less system. Sensor at the front of the fuel rail, sends signal to ECU, which sends a signal to the fuel pump modulator, which controls voltage to the in tank pump.
Smart alternators will eventually go into full charge when engine is in DFCO and AC compressor is not cycling, then if that is not sufficient charging will max during higher vacuum parameters.
Stop start alternators will have much greater capacity to charge quickly and will really pump the juice in a larger capacity battery under forced deceleration.
I still think lower displacement with electric supercharging under high loads will be a factor, especially with start stop alternator-starter systems and higher capacity lightweight batteries.
regards
Mech
The Following User Says Thank You to Old Mechanic For This Useful Post:
05-18-2011, 09:37 PM
Good additional info, guys. Thanks.
05-18-2011, 09:38 PM
...beats walking...
Originally Posted by Old Mechanic
...Stop start alternators will have much greater capacity to charge quickly and will really pump the juice in a larger capacity battery under forced deceleration.
...augmented by super-capacitors which are great for sudden dumps of current.
05-19-2011, 01:31 PM
Most new cars have return less fuel system. I remember when GM was promoting the same thing on the LS1 back in the late 90s.
05-19-2011, 01:43 PM
Interesting.
Is returnless automatically the same thing as having a variable output fuel pump? (I don't know.)
05-19-2011, 02:47 PM
Moderate your Moderation.
Probably not. I'm sure there's some difference, albeit a small one.
05-19-2011, 03:47 PM
#9 (permalink)
Yes for the most part all returnless systems have variable output fuel pump if not then at higher speeds and loads when demand for fuel is high it would not be able to provide fuel fast enough.
 I move at the speed of awesome.
