Old 10-29-2009, 12:11 AM   #11 (permalink)
puddleglum's Avatar
Rondo - '07 Rondo EX
90 day: 25.5 mpg (US)
Does air density also change with humidity like it does with temp. or is it not an issue. E.G. would air be substaintially denser in fog than a dry sunny day?
Is there any rule of thumb for the change in rolling resistance relating to temp. or is it dependant on the vehicle?
Old 10-29-2009, 01:53 AM   #12 (permalink)
Ernie Rogers
Fog and humidity have little effect
Hello, Puddlegum,
I am checking in a handbook for you (Handbook of Chemistry and Physics, CRC Press). At 95 deg F, here are the air densities at sea level--
Dry air at 95 F.........1.146 kg /cu.m.
100% humid air........1.122 kg /cu.m.
That's a density decrease of two percent. Suppose you are driving at a speed where 70% of the energy is used to oppose air drag. Then, a 50 mpg in dry air becomes---
50 x (0.7/0.98 + 0.3) = 50.7 mpg in 100% humidity and 95 F
At 70 deg F, the moisture content in humid air has less effect--
Dry air at 70 F.........1.201 kg /cu.m.
100% humid air........1.190 kg /cu.m. This is 1% less
Effect of greater density of cool air--
50 x 1.146 /1.201 = 47.7 mpg.
Effect of raising humidity from zero to 100%--
47.7 x (0.7/0.99 + .3) = 48.0 at 100% humidity and 70 F
If you lower the temperature another 25 degrees to 45 F, the effect of humidity drops to about 1/2%. (Air density rises to 1.226, a bigger effect.)
The effect of fog is to lower fuel economy, partially cancelling the effect of high humidity. The fog effect is smaller, so forget it.
I hope that puts your mind at ease.
Ernie Rogers
