Old 05-26-2008, 04:03 PM   #11 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
Nice to know they are always thinking about safety ... LOL
I would pray to be rear ended by a truck, that way it would all be over quickly.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-26-2008, 04:21 PM   #12 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Neon SE
90 day: 36.28 mpg (US)
S'Crew - '02 F150 Supercrew XLT
90 day: 16.4 mpg (US)
EX - '94 Explorer
90 day: 19.58 mpg (US)
Ranger - '90 Ranger
Last 3: 28.02 mpg (US)
At least they don't have it out on the streets though...
When it comes to Heroes, RENEGADES are mine!
Old 05-26-2008, 05:29 PM   #13 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
respect to that little wheel in the back! stood up quite long to that abuse.
it's not a totally bad idea to convert a front wheel drive car to a trike with a custom body.
fairly straightforward and a great platform for a boattail!
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 05-26-2008, 05:59 PM   #14 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
The only problem beside the rear end collision aspect is balance. The thing really wanted to stand on its end during heavy breaking and acceleration.
"Judge a person by their questions rather than their answers."
Old 05-26-2008, 07:16 PM   #15 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Hot rodders have done crazier stuff than this but with uni-body construction it would require the services of a very talented and well equipped body shop.
You could probably achieve getting the car down to 60% of initial width. A lot of it depends on where your engine sits. If it sits ahead of or behind the fron wheels you are good to go. If it sits between the wheels you are stymied.
Maybe a better and certainly still radical move would be to chop the top, if you are short enough to live with a low top sill.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 05-26-2008, 10:25 PM   #16 (permalink)
I envisioned something like the chopped Metro except I wouldn't stop at the roof. I'd split the whole thing down the middle - 60% of original width as previously posted sounds about right. Since I'd be going to electric I wouldn't need as much room as the engine requires but I don't know if that would crowd the transmission. I'm a big fan of Venture Vehicle's leaning trike so I wouldn't be opposed to a three wheel design except with three wheels I couldn't license it as a car and it couldn't pass as a modified motorcycle either. The airplane canopy idea would be cool but I think I'd have to leave the roof structure intact as much as possible to avoid big hassles with licensing (I think. It seems that I remember a requirement that states a modified car must employ all the safety features that were required during the year of mfr). There is a Triumph Spitfire in the area with a blown engine that I've been looking at - that would make a great donor. The whole idea is probably way beyond me but I think it would be a blast of a project.
Old 05-26-2008, 11:04 PM   #17 (permalink)
stinky - '97 metro lsi
90 day: 44.71 mpg (US)
what about using 4 cly axles in a 3cyl car. the motor is 4 inches shorter and the axles are 4 inches shorter. That gives u 8 inches. chop top also. that would take out the passenger seat, which is the area i would cut out, put like a kframe in front and weld the body back together.
Old 05-27-2008, 01:25 AM   #18 (permalink)
adrive7's Avatar
Ranger - '08 Ranger XL
90 day: 20.73 mpg (US)
Send a message via AIM to adrive7
One issue with chopping the car like you want is that doing so throws all the vehicle dynamics engineering that was done out the window. What you are left with is an unpredictable vehicle, possibly dangerous. You are probably better off doing something like the half metro. That way you maintain the original wheelbase and handling characteristics (for the most part).
Ohio State Baja SAE
Old 05-27-2008, 01:41 AM   #19 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I have to say props to the little wheel too
Also, this needs finishing but is kinda cool, might be easier just to go BUY a civic though :
Old 05-28-2008, 02:06 PM   #20 (permalink)
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
think about this .. make it far simpler than a total cut in half and still allows for 2 maybee 3 seat.. Tear drop it and make it 3 wheels , 2 in front and 1 in the rear.. then it could be licensed as a motor cycle , motor cycles have far less "regulations" for being legal , its basically 1 mirror, and one operable break..and signal and break lights for the most part.
Any way you do this its going top be a big project.. a extreme chop top may be the most effective easiest way to lessen your frontal area of the car.. imagine sloping back the windshield having side windows about 6" high.. that would take a huge chunk of frontal area of the car.... make a 4 seater a 2 seater where your almost reclining as you sit in it..
It would probably look pretty cool too.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 01:07 AM
I found another advantage to driving an ultra-low Cd car basjoos Aerodynamics 23 11-21-2010 04:32 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 10:37 PM
Article: Smart car offers fun along with fuel efficiency MetroMPG General Efficiency Discussion 0 01-29-2008 09:39 AM
