Old 04-09-2017, 10:38 AM   #181 (permalink)
SUVcruiser - '07 Ssangyong Kyron 2.0 XDI
90 day: 42.55 mpg (US)
SUVcruiser year 2017 - '07 Ssangyong Kyron 2.0XDI
Hybridcruiser 2023 - '13 Volvo V60 D6 AWD
90 day: 123.84 mpg (US)
What is the best/easyest way to kill a turbo commonrail diesel?
I want to do a killswitch.
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011+ 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
Old 04-13-2017, 11:13 PM   #182 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I wouldn't mind knowing the answer to that, because I have a push button starter that won't allow EOC what so ever. Four+ years of warranty left before I can do that though.
But with turbo diesel EOC opportunities are limited so I think the key is good enough? Here with RHD the right hand turns off the key while the left moves the shifter so there's even less to be gained from a switch, normally.
Old 04-13-2017, 11:59 PM   #183 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
Disrupt the crank or the cam sensor signal and the computer will shut it down. This will set a code. You might try unplugging the computer power relay, this may not set a code. The computer may see this as a key off condition.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 04-14-2017, 06:52 PM   #184 (permalink)
Diesels are often pointed out to be not so suitable to intermittent operation because they usually take longer to reach their optimum temperature but, if you manage for the engine to retain some heat in-between the idle shut-off cycles, the restart might not be so troublesome and the brake-specific fuel-efficiency might be not compromised so badly.
Old 04-14-2017, 08:08 PM   #185 (permalink)
Team Turbocharged!
Pickups
These days you'll see a CEL if you're lucky, but just as likely to go into limp home mode...
Old 05-01-2017, 03:03 PM   #186 (permalink)
Look what is uploaded to youtube.
How much hp (and fuel) is your mechanical fan stealing?
I can drift
Old 07-04-2017, 01:46 PM   #187 (permalink)
Brand new record. I was so close to drop below the 5liter consumption/100km..
1387km with 69,96l = 5,04l/100km
I can drift
Old 07-04-2017, 04:26 PM   #188 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Awesome!
Keep up the good work.
I wonder how i can create such a battery pack without investment.
I suppose i should start scavenging for dead laptop batteries.
Old 07-04-2017, 04:58 PM   #189 (permalink)
teoman's Avatar
A3 - '12 Audi A3
That is not hwo i imagined the clutch working.
I was under the impression that if the engine was kept cool enough then the fans would not engage at all.
Old 07-04-2017, 05:13 PM   #190 (permalink)
Elektric fans do not engage. They spin a bit, but that is because of the passing air trough it when driving. I have a viscosity clutch fan. And it is always spinning. Slipping when not needed. Non slipping when needed. So i removed it an placed an electric fan. Good for around 5% savings!
I can drift
