Old 04-18-2008, 04:33 PM   #1 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Ditch the Splash Guards?
First question -- I recall a thread at some point in time, that credited the front flaps for redirecting airflow around the rear wheel. Is there something to this?
The rear ones, I assume, are parachutes...
The car is rarely clean anymore, and I don't drive in gravel but maybe once or twice a year -- so the intended purpose is no longer an issue.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 04-18-2008, 04:53 PM   #2 (permalink)
Rather than ditching the splash guards, why not re-shape them to act as fairings and splash guards all in one?
Old 04-18-2008, 05:40 PM   #3 (permalink)
RH77's Avatar
Teggy Aero
Aero is my weak area, so bear with me here
The 2 left images are of the front flap, and the 3 is a shot of the rear. What do you recommend as far a fairing?
Last question -- if you look at the bottom of the bumper, theres a false indentation that looks like it's hollow. It appears to be molded into the bumper. If this was opened-up, would air exit more efficiently (I guess the license plate would need angled as well.
RH77
(I had the camera out for another project, so...)
EF5 / 22-May-2011
_
_
Old 04-18-2008, 05:47 PM   #4 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
To answer the bumper question, as of now (no bellypan), filling in the indentation would do nothing for you.
Old 04-18-2008, 05:48 PM   #5 (permalink)
You could use those flaps as partial templates for one end of an elongated teardrop-shape fairing. It could be carved from styrofoam, as is used in house insulation and sold at Home Depot, etc.. Or, you could ditch the mudflaps and just use the attach points for fairings.
Look at the rear wheel fairings on a Prius, as a guide.
As for the rear bumper cover, does it act like a parachute and scoop up air that is trying to escape from under the car? See various posts and pictures of Coroplast undertrays.
Old 04-18-2008, 05:51 PM   #6 (permalink)
Seems to me, the main priority should be the nose and wheels. By the time the airflow gets to the rear, it's so buggered that improvements would be marginal.
Old 04-18-2008, 06:04 PM   #7 (permalink)
RH77's Avatar
Good info...
Cutting out or filling that rear portion would be a permanent cut into the bumper, so good to know.
I'll take a look at the Prius for inspiration.
Aero effects really hit a harsh reality lately with strong winds. I may get bolder with trying new aero treatments (currently not a whole lot going on in that department).
RH77
EF5 / 22-May-2011
_
_
Old 04-18-2008, 07:00 PM   #8 (permalink)
Originally Posted by RH77 View Post
Good info...
RH77
Various posts here, such as those by Fabrio, offer good insight. Also, a visit to a Honda or Toyota dealer to see their latest stuff should help.
Old 04-18-2008, 07:34 PM   #9 (permalink)
RH77's Avatar
Funny you should mention! I was just out in the garage looking over (and under) the TSX, so I started investigating something...
Prius Cd: 0.26
TSX Cd: 0.27
The pics at the bottom show the treatments that are (somewhat) easily visible (sorry for the poor quality -- lighting and space is minimal -- raining outside).
The rear diffuser, rear spat, front spat, and ~1" chin spoiler (Not shown: partial undertray, flared fairings, and miscellaneous underbody pans).
On Teggy, I may start with an small undertray and carefully placed spats. Up front, I really need to figure out a grille block.
Are spats difficult to measure and place? I have plenty of black, scrap plastic to make them...
RH77
EF5 / 22-May-2011
_
_
Old 04-22-2008, 01:09 PM   #10 (permalink)
RH77's Avatar
Pulled the flaps
So last night I started tinkering with the aero challenges on this car...
I pulled the splash guards and saved them for future use.
Issue: The rear guards were part of the wheel well. Now I have a big hole in the rear 1/3 of the well.
Could this be beneficial to relieve pressure in this area, or could the air get stuck under the rear of the car and create additional drag?
RH77
EF5 / 22-May-2011
_
_
What to do when the ScanGauge shows your SUV gets horrible MPG? Ditch the ScanGauge! MetroMPG Hypermiling / EcoDriver's Ed 10 02-14-2008 06:26 PM
