Old 03-31-2008, 05:49 PM   #11 (permalink)
I connected the antenna wire directly to the defogger on the window. I'm not sure how its going to work from the fuse box but good luck.
Old 03-31-2008, 10:52 PM   #12 (permalink)
LUVMY02CREW's Avatar
TANK the fifth - '02 S10 Crew Cab 4x4 LS
90 day: 20.13 mpg (US)
Originally Posted by tjts1 View Post
Simple. Hook up the antenna wire to your rear window defogger.
No rear window defogger on the S10.....otherwise that sounds like it would work great.
I'm wondering if there would be some way to "hide" the antenna under the hood.......
I might need to look at some of the websites where folks spend an amazing amount of money on their trucks to turn them into show machines...they might have some slick way of going about it.
Old 04-02-2008, 10:52 PM   #13 (permalink)
Driving God
WTFM8's Avatar
Yoko - '97 Civic HX
90 day: 40.04 mpg (US)
Big Red - '91 CB750 Nighthawk
90 day: 46.29 mpg (US)
Fiddy - '01 SR 50 Elite
Last 3: 97.85 mpg (US)
Trolly - '01 7200 Multitrack Hybrid Road
90 day: 22.14 mpg (US)
I have been milling over this for a while and decided to just push my Honda antennas down into the A-pillar. Reception isn't as good in motion, but is fine when sitting still. Solves the aero issue and the RC car issue without doing much of anything to the car.
As for alternatives for you guys with the fender antennas, what's to stop you from simply removing the stand, and then relocate the entire antenna under or atop the dash?
Old 04-03-2008, 12:23 AM   #14 (permalink)
The antenna motor and gear box.
Old 04-03-2008, 12:30 AM   #15 (permalink)
Driving God
WTFM8's Avatar
Yoko - '97 Civic HX
Well, in that case, one could simply scavenge a static, one-piece antenna and eliminate the need for the gearbox and other electrics associated with that most decadent of luxury features: the automatic mast antenna!
Old 04-06-2008, 12:39 AM   #16 (permalink)
Oil Tycoon
mopo3's Avatar
Siray - '09 Yaris sedan
90 day: 39.41 mpg (US)
Mine is static I have been thinking over ways to move it inside. My rear defrost doesn't even work so I wonder if attaching it there is even an option.
Old 04-06-2008, 12:49 AM   #17 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
Duct tape it to something in the back of the interior. On my kit car the antenna is attached to a gas tank mounting bolt. Right beside the engine and it worked fine. Probably would not work as good in a metal bodied car but the antenna inside with enough sticking up where it can get the signal through the glass should work well enough for most people.
I will probably put the antenna on the back of the passenger seat on my new setup.
My Convertible Metro XFI Plug in Hybrid Project build log
Old 04-16-2008, 07:52 PM   #18 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
I removed mine. I had to plug the receptacle with a 6mm capscrew.
It didn't help my MPG noticeably, but now I have an ironclad reason not to listen to the goofiness on the radio.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 06-11-2008, 01:51 AM   #19 (permalink)
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
Any suggestions for a internal antenna for us folks that like to listen to the radio?
Old 06-11-2008, 10:21 AM   #20 (permalink)
JJW
The Crimson Jellybean - '08 Yaris
90 day: 41.8 mpg (US)
White's Elephant (in Black) - '02 Wrangler Sahara
Note: skip to the "short version" for the payoff of my rambling!
Maybe this is an opportunity to help with the antenna, as I've been an amateur radio operator since I was 16, and I'm the son of an RF engineer. There is nothing special about car radio antennas, they are as they appear - a piece of wire hanging out there in the breeze. The wire does have two important properties - Its length will be a certain fraction of the free-space wavelength of the signal you intend to receive, and it is electrically insulated from the ground plane (which in this case is the body of the car). Its length is engineered so that its impedance will match the design impedance of the radio. In practice, you can construct circuitry to match any length you like to that impedance, but its cheapest and easiest for the manufacturers to simply make them the length that matches. Most older cars seem to have an antenna designed to be 1/4 wavelength on the FM band, which presents about a 75 ohm impedance (depending on the ground plane, the design could be anywhere from 34 - 90 ohms impedance). This matches to the 75 ohm coax and the input of the radio, making the energy transfer from the antenna to the radio optimal (mismatch causes loss). In case you are curious, the wavelength in feet is equal to the speed of light in feet per second over the frequency in hertz. That would make a full wave on the AM band (I used 1200) 820 feet, and a full wave on the FM band (I used 102) 9.6 feet. To be a 1/4 wave at the FM frequency, the antenna would be about 2.4 feet long. It suffices to say that cut for anywhere in the FM band, the antenna will be between 2.2 and 2.5 feet long as a car body isn't a perfect ground plane, so the dimensions could shift somewhat. That presents the problem that the antenna is very very short compared to the AM band wavelength, which means it will not present the same 75 ohm impedance on that band to the radio. There is usually some matching circuitry in the radio to match the very high impedance that the antenna would be on the AM band to the receiver. Some cars run preamplifiers and matching circuits outboard of the radio, and it seems to be very common with the short stubby antennas that are so common now.
I'm sure you all enthralled, but let me bring this back to hypermiling and your antenna, and the subject of using the defroster grid. All the radio really cares about is the impedance of your antenna. If the impedance right, at the size of our cars, the only other real variable is size. The bigger the better, up to a point (for reasons that would be equally as boring to you). Antennas can be thought of as having two halves.. I'm sure you've seen this on old TV rabbit ears. With the usual car antenna, the antenna makes up half of the system, and the body of the car makes up the other half. Clever eh? Radio waves don't care what it looks like. SO, when you see antennas in windows, you'll note that they have two halves.. they aren't using the body as another half.
A 1/2 wave dipole will have a feed impedance of about 50 ohms in free space. What's a halfwave dipole? It's like two antenna elements in a straight line facing away from each other and fed in the center. Each element is a 1/4 wave, so the total size of the antenna is 1/2 wavelength. Think TV rabbit ears spread as far apart as possible, so that they are flat. like this:
---------------------0 0-----------------------
This gives us two options for glass mounted antennas. You can make a single element, make it about 1/4 wavelength long, and connect that to the center of your radio antenna feedline (the coax going to the radio). Then connect the shield, which is the ground, to the car body.
The other option, is to make two elements, each 1/4 wavelength long, and connect to them in the middle. The center of the coax to one, the sheild to the other.
So, if you are using the defroster grid, attach to it and cut it to be an element of about the right length (2.2-2.5 feet should be about right). If you don't have a defroster grid, you can use cheap metal foil tape and stick it to the window. Size isn't really too important, a thin strip would work fine.
Since we are only talking about receiving, none of the dimensions are very critical. On the transmitter end, having a very small mismatch can cause a large amount of power to be used up as heat instead of transmitted, and since they are dealing with thousands of watts it is something to worry about. On our receiving end, the amount of power we are talking about is tiny.. a strong signal might impart a few microvolts to the input of your radio, which is why most of the radio is just high gain amplification.
One last note, Broadcast radio is almost always transmitted with vertical polarization. A vertical antenna will receive that signal with greater efficiency than a horizontal one, by about 6dB. Don't worry about the specifics, just know vertical is better for a car antenna.
So the short version? Stick some metal tape to one of your windows. If you attach the shield to the body, you can use 2.2-2.5 feet. If you don't, use two pieces, each 2.2 - 2.5 feet. Run the antenna vertically if possible. Connect to your new antenna using 75 ohm coax available just about anywhere (RG-59 is extremely cheap at home depot). I like copper tape, but I've used the metal tape sold for insulation purposes at home depot. The best way to connect to it is solder, but you could probably leave "tabs" to connect to with a twist-n-tape connection if you had to.
I've used the metal foil tape on my car windows to transmit 50 watts @ 144 Mhz before and had no issues, so it will work well for receiving. That same setup contacted the ISS Should cost you less than 5 dollars.
Your chances of damaging the radio are just about nil. The worst thing that could happen is that you short the antenna center to the ground, which would only result in crappy reception, and would easily be fixed by getting rid of the short.
Hope I didn't bore you all to death!
