04-20-2011, 08:56 AM
Does the display actually turn off?
I thought the display would turn off after 7 mins (default) of no activity, or is there potentially something wrong in the code, or something upsetting it?
04-20-2011, 09:38 AM
needs more cowbell
The backlight LED should turn off if it is on to conserve power. The numbers still display though (sometimes useful so you can see what your last trip mpg before starting the car) and use little current.
04-20-2011, 06:36 PM
Yeah, the back lit LED definitely hasn't turned off overnight...
I'm going to try change the default time and see if that wakes it up.
This is using the Canadian version chip, so will send him a PM if I can't figure it out.
EDIT: Just halved the default time and it looks like the backlight has turned off, but will know for certain later on today, if its working as it should.
04-20-2011, 09:46 PM
Actually now I'm not sure of what is going on...
I can't tell if the Backlight is on or not, or if its just the brightness that has changed somehow...
Will try to figure it out over the next few days...
04-20-2011, 11:06 PM
needs more cowbell
FYI, prebuilt hardware 1.3 uses an npn, as does the latest CPP. You might have a PNP driving the backlight, in which case you have to invert the signal, i.e. subtract all the values in this line from 255
byte brightness[] = { 0, 41, 84, 128 }; //middle button cycles through these brightness settings
becomes
byte brightness[] = { 255, 214, 171, 128 }; //middle button cycles through these brightness settings
maybe..
If this it what is going on it will be obvious if when you press the middle button, the display gets dimmer several times before resetting to the brighter setting. When it "sleeps", it sets the display to the first value which might be "extremely bright" in your case (the pwm of 0 means the control pin is constantly at ground, which activates the pnp transistor, but disables the npn transistor in newer versions.)
04-20-2011, 11:21 PM
This is the prebuilt 1.3 off the Opengauge website (ordered 6 or so weeks ago), but with the Canadian code chip from another member.
Ok, so this is what I can confirm. At Brightness 0, the screen is the brightest, and the lowest at Brightness 3.
Now the issue is, apart from it being back to front (or is that how its suppose to be?) is that even at the lowest Brightness level, that still lights up the car like a Christmas tree and obviously perks the interest of passers by...
Is there a particular wire that I can setup a flick switch to, so that I can turn off the LCD, but not upset the EEPROM which needs to remain on?
EDIT: Had a quick look on wiki, that 5V input to the LCD, any issues with using that hooked up to a switch?
04-20-2011, 11:33 PM
needs more cowbell
Well if you have 1.3 hardware then I would try the brightness settings from the corresponding software (the cpp)
Unless someone has decided that what you are using needed to be completely rewritten and that sentence makes no sense at all.
04-21-2011, 03:01 AM
dcb, I have no hardware to READ / EDIT the chip.....
I'll PM the code writer to see what he can see in the code.
04-21-2011, 07:19 PM
#9 (permalink)
dcb,
Here is the current code I am using > "Canadian Metric 0.81m"
Canadian version for kilometers
At 'Brightness 0', the screen is the brightest
At 'Brightness 3', the screen is the dimmest
Does this suggest I have a PNP driving the backlight? Or because it is the Opengauge 1.3 assembled unit (NPN), the code was altered for a PNP driven backlight unit?
I had a quick look through the code, but I think a lot of the Objects have been renamed, so would have to scan it line by line...
04-21-2011, 07:22 PM
#10 (permalink)
needs more cowbell
I added L/100km to the chip that came with it. The chip you have isn't compatible without reprogramming. Good luck with that
