Originally Posted by dcb
Unless someone has decided that what you are using needed to be completely rewritten and that sentence makes no sense at all.
dcb,
Here is the current code I am using > "Canadian Metric 0.81m"
http://ecomodder.com/forum/showthrea...tml#post202348
At 'Brightness 0', the screen is the brightest
At 'Brightness 3', the screen is the dimmest
Does this suggest I have a PNP driving the backlight? Or because it is the Opengauge 1.3 assembled unit (NPN), the code was altered for a PNP driven backlight unit?
I had a quick look through the code, but I think a lot of the Objects have been renamed, so would have to scan it line by line...
