Old 04-23-2013, 06:44 PM   #191 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
i will know next time i fillup
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
Old 05-04-2013, 11:44 PM   #192 (permalink)
40-60-40 MPH P&G
Update :
I did 93 MPG coming back from south of Montreal :
I filled up recently and did 65.23 MPG. What I remember of my Averages is about 5 or 6% better that my fillup result. My 80+ MPG trips were only in the end of the tank, the first trips were in colder temps and had significantly lower MPG. The lowest trip was around 58 MPG.
I also started my Kammback Extension Mod. It is made of lexan and strenghtened by an aluminium frame. It will be hold up by coroplast support and will be attached by bungie cord on the trunk. The extension is connected with the other part of the kammback by hinges, so ye can open the kammback to have an access to the trunk.
This is the angle of the kammback from the rear :
From the side :
I also removed the Power-Steering Pump. It weighted around 10 lbs.
BIG SURPRISE THIS WEEK!
MPG=1 TIME=0
The Following 4 Users Say Thank You to echo-francis For This Useful Post:
blownb310 (05-05-2013), christofoo (06-21-2013), Flakbadger (05-05-2013), Weather Spotter (05-05-2013)
Old 05-05-2013, 10:03 AM   #193 (permalink)
blownb310's Avatar
Saab EV - '19 Chevy Bolt EV LT
Pierre - '07 ZENN MC2 Base
Looking great Francis! I can't wait to see the car in Montreal next month!
2007 ZENN and 2019 Chevy Bolt EV 145,000 oil free miles to date.
Old 05-09-2013, 12:54 PM   #194 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Francis in the modding process of the Kammback Extension :
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Old 05-12-2013, 01:46 AM   #195 (permalink)
40-60-40 MPH P&G
update: i finished my kammback extension :
and I cleaned up the mess of wire under my hood created by my 3 heaters
MPG=1 TIME=0
Old 05-12-2013, 09:04 AM   #196 (permalink)
blownb310's Avatar
Looks great. I can appreciate the amount of effort it took to make it. Very cool.
Old 05-13-2013, 08:34 AM   #197 (permalink)
40-60-40 MPH P&G
today I forgot to plug my car and I got 10mpg less than average
MPG=1 TIME=0
Old 05-13-2013, 04:40 PM   #198 (permalink)
maczo's Avatar
scrapcento - '99 fiat seicento
90 day: 30.15 mpg (US)
fokus - '08 Ford Focus
90 day: 31.15 mpg (US)
tdm - '95 Yamaha TDM 850
90 day: 27.72 mpg (US)
vespa - '04 Piaggio Vespa ET4
90 day: 57.6 mpg (US)
PCX - '10 Honda PCX
90 day: 78.33 mpg (US)
avensis - '13 Toyota Avensis
90 day: 41.72 mpg (US)
I like the design! Is it mounted with duct tape forever or are you planning on something less permanent?
The Scrapcento thread
Old 05-13-2013, 05:08 PM   #199 (permalink)
I really like the hinge idea, some of us have been discussing fixing the rear portion of a sedan and I think that is the best solution by far. You wrote that it is attached to the trunk with bungee cords, but did you duct-tape the rest to the car?
That is our other obstacle: Attachment.
Old 05-13-2013, 05:27 PM   #200 (permalink)
40-60-40 MPH P&G
the first part of the kammback is only duct taped to the car and the second part is hinged to the frist part . the bungee cords are there to prevent the second part to fly off with the wind
if there was a (no duct tape) solution at low cost I would take it
MPG=1 TIME=0
alt delete, belly pan, electric water pump, grill block, hypermiler, modding, toyota echo
