Old 08-25-2011, 11:58 PM   #1 (permalink)
I are aerodynamic kitteh!
t vago's Avatar
2000 Fiat Dakota Quad Cab - '00 Dakota Quad Cab SLT
90 day: 18.33 mpg (US)
Dakota A-B-A HAI - '00 Dakota Quad Cab SLT
90 day: 19.38 mpg (US)
Electrohydraulic Power Steering
As the title hints, I think I will pursue installing one of these critters into my Dakota. I have a 2001-2005 Toyota MR2 power steering pump module (a combined electric motor, pump, reservoir, and controller), and I found these nice instructions over here at DIYElectricCar.com.
I should be able to re-install the stock crank pulley (I swapped it with an underdrive pulley a few weeks ago and saw a whopping 1% improvement in FE), and once I do that, I should be able to get a shorter serpentine belt that would bypass the factory power steering pump altogether.
I am looking to get more than a 1% FE improvement. Specifically, I am looking at a target of around 3%, which would raise my average FE from around 20 MPG right now, to around 20.5 MPG. Not much, to be sure, but I already have most of the needed equipment floating around already in my garage - 60 amp rated relay, 4-gauge fuse holder, 4-gauge wires, electrical connectors of all sorts (crimp+solder and Weatherpak) 18-gauge wires, power steering return line, factory service manual, and (of course) the pump unit itself. I just need a pressure hose with a 16mm x 1.5 inverted flare fitting on one end and a 18mm x 1.5 o-ring fitting on the other end, a custom-made mounting bracket (and a mounting point), and a shorter (~82 inch) serpentine belt.
The big challenge I am seeing right now is where to install this thing. It's not very small, and of course the engine bay is a little crowded.
Not quite my engine bay, but similar enough so that you can see what I'm dealing with.
2000 Dodge Dakota Quad Cab
2002 Chrysler Sebring Convertible GTC with transplanted 3.5L LH engine
The Following User Says Thank You to t vago For This Useful Post:
Tygen1 (08-26-2011)
Old 08-26-2011, 12:45 PM   #2 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
Very nice, keep us up to date!
Old 08-26-2011, 02:22 PM   #3 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
looks like your a prime candidate to use George and I's alternator improvement circuit
The Following User Says Thank You to ConnClark For This Useful Post:
t vago (08-28-2011)
Old 08-28-2011, 06:54 AM   #4 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
If you are having too much difficulty finding room to stuff the electro hydraulic unit in there, here is what I would like to put in my car:
Hydraulicstore.com - 877.778.3533 -
Notice the replacement pump clutch section.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
t vago (08-28-2011)
Old 08-28-2011, 08:16 AM   #5 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Were I do to something like that, I'd disconnect the pump and loop the lines to the box. Or get a manual box if there's one that'll bolt in.
Old 08-28-2011, 05:03 PM   #6 (permalink)
t vago's Avatar
I think I have found a good spot for the electric pump module ("good" meaning that it'll actually fit and be oriented correctly). However, there are a couple of caveats.
First, the stock power steering pump, reservoir, and PS fluid cooler will have to be removed as a unit. I will not be able to keep the stock unit in the engine bay and have the electric pump installed at the same time.
Second, the pump will very likely sit low in the engine bay, which will make checking the power steering fluid level somewhat of a challenge.
I think I can live with both of these caveats. I will make some mounting brackets to mount the electric pump module on the truck chassis, and then wire it up.
After some digging around, I could find the input and output pins on the pump module itself.
A1 - high amperage +12VDC
A2 - high amperage ground
B1 - idle up output to Toyota ECM (active high or active low?)
B2 - 4 pulse/rev speed sensor input
B3 - "TC" diagnostic connector
B4 - N/C
B5 - EHPS relay control (active low)
B6 - WOT cutout input from Toyota ECM (possibly active low)
B7 - "TS" diagnostic connector
B8 - N/C
C1 - switched ignition +12VDC
C2 - "SIL" diagnostic connector
C3 - N/C
C4 - warning lamp output (possibly active high)
So, it should be a simple matter to come up with a T flip-flop to interface my truck's VSS output (8 pulse/rev) to the input of the pump. I will probably rig up a small relay that switches a ground signal, controlled by the idle-up signal, that would be fed as the power steering pressure switch signal into my truck's engine computer. I'll probably end up using some sort of comparator circuit, taking its input from the throttle position sensor, which would provide the WOT cutout input for the pump module. Wiring up the warning light ought to be pretty simple, too.
Old 08-28-2011, 09:20 PM   #7 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
steering angle sensor
you have not made mention of the steering angle sensor input , to the power steering computer / controller / black box
on VW Audi this is a critical input delivered by the network to the steering rack which has the PS pump built in
key work here is
network -
no doubt the partial toyota network that may exist in the p/s unit does not communicate with the dodge network .
it may function anyway as the VW PS systems will function even if the system codeing is set incorrectly so that the system looks for the steering angle sensor in the wrong location -
but - those systems set DTCs - every where
the WOT cutout can be sampled at the AC compressor as it has a WOT cutout as well , the TPS is not a good choice for this input .
Old 08-28-2011, 10:00 PM   #8 (permalink)
t vago's Avatar
Steering angle sensor? Nope.
I have not made mention of such a sensor, because this particular module does not require such a sensor. It uses an internal hydraulic pressure sensor to sense demand. The older MR2 EHPS used several modules and sensors, including what you're describing. This one is from a newer MR2, and is almost completely self-contained.
You're right. However, this is not a concern. This module was not designed to be smart enough to require a network for operation - CANBUS, ISO, J-1853, CCD, or otherwise.
The pump will still operate, regardless of whether or not I hook up the WOT cutout wire and idle up command wire. Those two wires are "nice-to-have" wires, but they're not strictly necessary for operation.
The speed signal wire is the most important signal wire, because it will allow the module to determine when to reduce its output power. The warning lamp signal is the second most important signal wire, because that will tell me if something's wrong.
The diagnostic wires are not going to be hooked to anything, since they only went to a diagnostic connector on the MR2 to begin with. This module was never interfaced with the MR2 network.
Not entirely sure how this would work. Do you mean that I should tap the wiring that drives the A/C compressor clutch?
dakota, dodge, electric, power, steering
