Old 12-05-2011, 03:20 PM   #31 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle - '01 Echo Sedan
90 day: 42.53 mpg (US)
Hehe ! That active grille is looking pretty good augustinionut !
Old 12-07-2011, 09:12 PM   #32 (permalink)
puddleglum's Avatar
Rondo - '07 Rondo EX
90 day: 25.5 mpg (US)
Grill block looks excellent, but I thought that having it open slowly so you could only keep it partially open was a good idea. Why did you change it?
Old 12-08-2011, 11:51 AM   #33 (permalink)
This is more efficient. The old dc motor was too weak.
EDIT: automated version with a 75 degree termostat
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 03:09 PM
