Old 01-11-2013, 12:15 PM   #61 (permalink)
Off topic but have no problem defining a vehicle by its weight class. A 700 lb 4 wheeler shouldn't have the same tax rate as 4k + lb 3 wheeler. The wear on roads from the extra weight.
With my Wrangler I average 40 mpg. Triumph Speedmaster 60 mpg + Jeep 20 mpg = 40 mpg!
Old 01-11-2013, 12:17 PM   #62 (permalink)
99.5 Golf TDI - '99 Golf GL
However, what about scooters? You don't sit astride them, yet they're definitely motorcycles.
Old 01-11-2013, 02:25 PM   #63 (permalink)
PSmodder lurker
botsapper's Avatar
...if you are still allergic to the number three... http://www.likecool.com/Proxima--Concept--Car.html
Old 01-11-2013, 04:42 PM   #64 (permalink)
That's just stupid, it has most of the problems of a three-wheeler, without the legal advantages.
Old 01-11-2013, 05:57 PM   #65 (permalink)
I must agree but.....it's got great lines! Fix the back wheel and I'd like one, when they hit the $6800 price point or about. $55K rimes with No way.
Old 01-11-2013, 06:23 PM   #66 (permalink)
OK back on reverse engineering. So if it does 0-60 in 9.6 sec with a 70 HP motor can we guess its weight? Maybe assume the engine is a Suzuki and use the weight of the car that engine is used in and those 0-60 times? Lets see those mathletes!
Old 01-11-2013, 06:32 PM   #67 (permalink)
The aerodynamics are a factor, though.
But, 0-60 mph Calculator for Cars estimates it at 1565 lbs.
Old 01-11-2013, 07:17 PM   #68 (permalink)
OK so between 100 and 200 less for wet weight of trike. Seem fairly accurate. I checked with my SHO specs and came close enough.
Old 01-11-2013, 08:48 PM   #69 (permalink)
The engine is still between your legs, technically.
I'd heard (total hearsay from somewhere else) they were thinking of removing the tax breaks for quadricycles? That sort of makes me sad.
Old 01-12-2013, 09:42 AM   #70 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
They just hinted at it weighing around 800 pounds.
I'll have to look it up, but here in WI a motorcycle has to weigh under around 1,200 or 1,500 pounds, not sure exactly, but I know that there is a weight limit.
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
