Old 08-31-2012, 06:16 PM   #1 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Extending the Decklid (Toyota Echo)
Hey guys !
It is time for me to concentrate my efforts and resources at some in-depth refinement of my Echo's deck-lid. Basically, I want to build an extension of some sort that is tapered, following the car's original lines. I aiming towards a deck-lid a la Ford Fusion 999. But perhaps not as pronounced length-wise. But who knows, with a little convincing, I might cave in...
See picture for reference.
I do welcome suggestions, be it concerning the decklid or any other mod leading to decent gains. You guys are the pros in this domain and I would be a fool to turn down any useful insight. However, at this moment, I do not plan on installing a boat tail. I am aware of the gains but I simply do not wish to go down that path...for the moment.
Also, I plan on providing some preliminary tuft testing videos of the airflow on the rear glass. It should help you guys decipher what is going on back there. Given that we have a 3-day weekend, I might have a video by Monday. Heck, I have to put that GoPro camera to good use..
To conlude this post, here is a pic of my car.
For some reason, I cannot find technical drawings for the first-gen Echo. It does not look good aerodynamically-speaking but the stock Cd is 0.29 so in reality, it is not that bad.
TIA for ANY feedback ! Much appreciated.
Old 08-31-2012, 06:24 PM   #2 (permalink)
90 day: 70.75 mpg (US)
90 day: 62.14 mpg (US)
Have you ever tuft-tested the decklid? It's short, and the rear glass is fairly steep, so I wonder if it's completely turbulent back there, or whether there's attachment on the trailing edge (the roof does curve down above the rear glass...)
Old 08-31-2012, 06:35 PM   #3 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
try and see what she does
Old 08-31-2012, 06:35 PM   #4 (permalink)
CigaR007's Avatar
Can't say I ever tuft-tested the decklid. I will do my best to capture that vital information in the coming days, as it will be key for the design of the extension. If and that is a BIG if, flow does not re-attach at the decklid, would resorting to homemade vortex generators help the air flow, especially in the roof-to-glass transition ? I know that they are very hard to tweak but could they improve the flow when combined with a decklid extension. The rear glass is steep indeed.
Anyhow, I will come up with a tuft-testing video and we will know for sure.
Old 08-31-2012, 06:37 PM   #5 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Nice idea! If it prove any improvement, Francis and I might try the same on the Echo-Troll as well!
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Old 08-31-2012, 11:23 PM   #6 (permalink)
In the event of no re-attachment:
VG's would likely help get more flow onto the decklid, but at what cost? Don't know.
Another option is to raise the height of the decklid's upper surface to get closer to the template.
Simplest option is a NASCAR type of spoiler.
Old 09-01-2012, 03:42 PM   #7 (permalink)
CigaR007's Avatar
Any tips on how to prepare a tuft testing ? Camera is set, just need to clean the rear glass and decklid prior to installing the wool tufts. Is there an optimal number of wool tufts, length and positioning ?
Old 09-01-2012, 07:58 PM   #8 (permalink)
CigaR007's Avatar
Tuft testing has been done. Video will be edited this evening and posted tomorrow.
Shot at 2012-09-01
Shot at 2012-09-01
Old 09-02-2012, 02:24 PM   #9 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
You can't find blueprints because in the rest of the world it was called the Platz or Yaris (first generation).
They're out there, but they're also small.
Looking forward to the tufts!
The Following 2 Users Say Thank You to Sven7 For This Useful Post:
Cd (09-08-2012), MetroMPG (09-05-2012)
Old 09-02-2012, 05:11 PM   #10 (permalink)
CigaR007's Avatar
Here is the video to mark my 500th post ! It is available in 720p, if desired.
There is clearly a bubble of turbulent air in the middle of the rear glass. Whereas the sides are stabler, mainly due to vortices being generated by the C-pillar. The airflow does seem to partially re-attach on the decklid.
Awaiting your thoughts and suggestions !
The Following 2 Users Say Thank You to CigaR007 For This Useful Post:
aerohead (09-06-2012), HyperMileQC (09-03-2012)
