Old 05-16-2014, 11:15 AM   #1 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
Front Grill block finished (mostly)
So aside from needing a ton of hours of sanding and repainting to make it all smooth, I've basically finished off the front grill blocks. Its all bondo and expanding foam. I decided to make it permanent after figuring out the "hole size" with duct tape. Coolant temps never go above 206, and usually stay around 198-202 range.
All-in-all, I'd call it a success!
The Following 5 Users Say Thank You to whatmaycome14 For This Useful Post:
AndrzejM (03-01-2015), DukeEcoNukem (06-13-2016), mcrews (05-26-2014), mikeyjd (05-16-2014), Xist (05-16-2014)
Old 05-16-2014, 11:53 AM   #2 (permalink)
Wow, thats quite a bit of work. Nice job. Do you have any close up shots?
Old 05-16-2014, 12:25 PM   #3 (permalink)
I'll post more close up shots after I've gotten a bit more work done with it... it's embarrassing the amount of sanding that still needs to be done.
You know what, I change my mind. I'll post more photos today. To hell with when I'll have time for more sanding. That could take a month!
Old 05-16-2014, 12:33 PM   #4 (permalink)
Haha... yeah I know how that goes.
Old 05-16-2014, 12:57 PM   #5 (permalink)
I often forget that there will be a lot less judgement HERE than I typically get from "normal" people.
I've put about 5hrs of sanding into it already, and I figure I've got AT LEAST 10hrs more to go. I need to go buy more sand paper...
Pictures:
The Following 4 Users Say Thank You to whatmaycome14 For This Useful Post:
Fat Charlie (05-16-2014), mcrews (05-26-2014), mikeyjd (05-16-2014), The donkey CRX (05-31-2014)
Old 05-16-2014, 01:15 PM   #6 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
It's gonna be nice when done. I like it better than OEM already. The upper looks great already.
The Following User Says Thank You to mikeyjd For This Useful Post:
whatmaycome14 (05-25-2014)
Old 05-16-2014, 01:46 PM   #7 (permalink)
That looks pretty darn good.
I don't know if you have one of these, or can make something similar out of a 1x4 or something, but when I was doing my pretty grill block it came in very handy.
Keysco Speed File Sanding Board — 17in. Long, Model# 77527 | Sanders| Northern Tool + Equipment
The Following 2 Users Say Thank You to Daox For This Useful Post:
whatmaycome14 (05-25-2014), Xist (05-16-2014)
Old 05-25-2014, 12:43 PM   #8 (permalink)
Well, I think I'm going to have to shift gears a bit. I've recently learned that Bondo doesn't work well with plastics like the front bumper. (I wish I would've known that!) So in the areas around the edges where there isn't any expanding foam and the bond is contacting the plastic it will separate and just cause a bunch of problems. I'm not sure how to proceed. I'm thinking fiberglass.
Old 05-25-2014, 03:24 PM   #9 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
That's what I did, and it seemed to work well.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
DukeEcoNukem (06-13-2016), whatmaycome14 (05-26-2014)
Old 05-26-2014, 11:04 AM   #10 (permalink)
EXACTLY the result I'm looking for... Perfect! Thanks for sharing. I know what I have to do now.
The Following User Says Thank You to whatmaycome14 For This Useful Post:
mcrews (05-26-2014)
