View Poll Results: What grade gas do you use?
Regular
51 |
82.26% |
Midgrade
7 |
11.29% |
Premium
4 |
6.45% |
09-03-2008, 12:04 PM
VIVA LA MPG RESISTANCE
Fuel Grades
Ok, who uses regular gas, and who uses premium? If you use premium have you noticed an FE difference in the two?
09-03-2008, 12:27 PM
Moderator
It depends. I buy regular for the Elantra and Shell V-Power (premium) diesel for the TDI.
09-03-2008, 12:42 PM
i choose regular for my cavalier, but when i had my focus i had the ecu flashed and could only use premium.
im going to on the next two tanks however give premium a shot and see if there is any difference, but i look at it as regular is cheaper, so it would have to be a great difference in FE to make the complete switch.
09-03-2008, 01:02 PM
I use 89 in my DD an 87 Turbo Volvo. The owners manual says 91 but since I hardly ever go into boost why should I spend the money on octane I'm not using. 87 makes the car run poorly and it has pretty poor pick up if you have to put the pedal down.
09-03-2008, 01:08 PM
I've used both premium and regular in my bike and have noticed no difference. The manual says use premium, but I have a small engine that just doesn't have the compression to completely burn premium.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
09-03-2008, 02:03 PM
Pokémoderator
Will -
I ran Chevron 91 last year because of my HAI (hot-air-intake => lean-burn => higher octane is better to avoid knocking/pinging). I switched to 87 when the gas prices got too high, didn't notice a change, and never switched back.
I have a hankering to up the octane again because my car is *different* from last year. I also think it has been on 87 for so long that I might be able to detect a difference in the way it drives (big *shrug*).
CarloSW2
09-03-2008, 02:11 PM
Even if it did yield better FE, from a cost perspective it would have to make up for that 20 cents or so per gallon to truly make it economical. I wouldn't mind seeing some data on it. I'm not quite sure it's worth the gamble of higher fuel prices for few tanks, personally. I'm sure it's been looked at before somewhere.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
09-03-2008, 03:09 PM
Bailout at CleanMPG, with his commute up and over a rocky mountain pass in a Yaris, tested this.
regular was best
-4% mpg with midgrade
-9% mpg with premium
I think I'll stick with the cheap stuff.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
09-03-2008, 04:07 PM
#9 (permalink)
Hybrid Student Driver
When I had my HAI (160F) I used premium to prevent detonation, but the cost-benefit was off. Now, intake temps are 100-120F with full advanced timing and no ping with near-full load (some knocking at high RPM, so I don't go there much).
The TSX "requires premium", but runs just fine on regular. The savings add up. FE is the same too. There's a bit of stumble from time-to-time at 6k RPM with VTEC, but again, very rarely used.
Long live 87!
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
 _
 _
09-03-2008, 04:36 PM
#10 (permalink)
X-Frenchy: very
In my 11 years old turbo diesel I used only regular and mid-grade during years.
One of the rules to eco-drive is to shift up soon, but it had difficulties to stay at 1500rpm. During the first premium tank I felt changes and now (at 4th tank) it can accelerate from 1200-1300rpm.
Because it permits me to improve my eco-driving style premium permits me to have a better mileage. Currently I'm staying with the premium as while I'm saving 33% of diesel, I'm saving 30% of money. May be one day it will be the placebo effect... My mechanic maintains my car, but premium seams doing things my mechanic doesn't...
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving: - 5725.5 kg CO2 (5342.6+382.9)
- Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
