Old 10-23-2008, 09:26 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
Geo Metro Block Heater How-to
I picked up a Kat's 850watt block heater today. Part #13080 at my local Napa store. It retails for around $75 but I got a discount because I am good friends with some of them up there.
I had to buy 5/8" heater core hose, they had a 6ft. piece for $5.94 at Advance auto. More than enough for this project, enough to replace all the heater hoses. Might as well while you are doing this.
I also picked up a timer at Wal-mart that I am going to set for 1 1/2 hours before I leave for work in the mornings. I figured up this would cost me $1.27 for a month to use. Not to shabby for a nice warm car in the morning.
The packaging.
The kit, notice the MD can by it the heater is fairly small.
This is how you will want to orient your bracket.
A good mounting location I found, just make sure it out of the path of the cv shaft. That would not be good. The heater also has to be lower than where you are connecting to allow gravity to do it's job.
This is the hose I tied into.
Done enjoy a nice warm car in the mornings. Also the added benefit of better fuel economy.
Make sure to "burp" the system of air, and when refilling system leave outlet of heater unhooked. Watch for coolant to fill the heater before connecting upper "outlet hose" marked by an arrow on the case of heater.
Old 10-23-2008, 09:41 PM   #2 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Looks much easier than a factory style install and more efficient than oil heaters.
Old 10-24-2008, 06:13 PM   #3 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
Has anyone combined different style heaters on one car? Didn't you do something on this, Darin? I would think that an oil heater coupled with a coolant recirculatory heater would make the most difference, but still have diminishing returns... I would like to make such a system.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 10-24-2008, 07:04 PM   #4 (permalink)
Addicted
bbjsw10's Avatar
I thought about doing this but instead of oil, use one of the 200w magnetic on the transmission to warm the tranny oil up. I feel the engine oil will warm pretty quickly when the motor is warmed by the coolant heater. The heat from block is sure to transfer to oil pan I would think.
Old 10-24-2008, 09:46 PM   #5 (permalink)
2006 Matrix - '06 Matrix base
90 day: 37.5 mpg (US)
Danger will Robinson Danger!!!!
Years ago a coworker of mine installed a circulating coolant heater from a big truck in his car. The first cold day he tried it, he went out to his car, started it and turned on the defrost. His windshield broke due to thermal expansion. 850W seems excessive for a Metro engine; please be careful if you need to use the defrost.
Old 10-24-2008, 10:01 PM   #6 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Hi knowbodies - I've never seen more than about 130 F above ambient using my 800 watt heater (almost identical to yours, bbjsw10).
from: Experiment: how long should a block heater be plugged in? - MetroMPG.com
That's still well below normal operating temperature.
I guess it's still possible to crack the windshield if it's super cold outside (like -35 C / -31F) ... oh look, you live in Moose Jaw!
I have an external element style 300w OEM block heater + this convection tank style 800w one. I rarely use them both at the same time, unless I'm in a "hurry" and don't want to wait for the 800w one.
Old 10-24-2008, 10:06 PM   #7 (permalink)
Also, don't forget to leave your temp slider on "hot" inside the car when you plug in - you have to give the convection somewhere to go!
Looking forward to your impressions of the heater. I love mine.
You know the unusual sounds a really, really cold (like -10 and below, C) engine makes when it first starts up? I haven't heard that for a long time.
Old 10-24-2008, 10:12 PM   #8 (permalink)
Funny's Avatar
Since you have the equipment attached to your whip already, would you be willing to make another experiment and temperature every 15 minutes graph using the two heaters at the same time? I would really like to see how quickly it gets up to temp and how it affects your MPGs...
I really would like to do that kind of modification on my car...
American by right
Ecomodder by choice
Old 10-24-2008, 10:21 PM   #9 (permalink)
Ask and ye shall receive!
From: Experiment: how long should a block heater be plugged in? - MetroMPG.com
I haven't tried to measure impact on fuel economy because I didn't think I could control enough variables to get meaningful results.
Old 10-24-2008, 11:19 PM   #10 (permalink)
Funny's Avatar
Sweet, thanks a bunch Darin. I think that heating multiple fluids in a car would be better for overall fuel consumption. Oil, Tranny and Coolant. I am really thinking about doing this...
American by right
Ecomodder by choice
Civic Block Heater Install TomO DIY / How-to 42 04-04-2012 08:24 PM
2003 Toyota Matrix Block Heater Daox EcoModding Central 23 09-08-2010 01:19 PM
My 1989 Geo Metro Story owlafaye Introductions 2 10-05-2008 06:31 PM
An Engine Block Heater in San Jose Who EcoModding Central 20 07-28-2008 05:44 PM
1990 Geo Metro Idle test cinaroh EcoModding Central 2 07-08-2008 10:15 PM
