Old 04-03-2013, 11:27 AM   #1 (permalink)
rusty - '94 Honda Accord EX
90 day: 35.13 mpg (US)
Thermostat question
I have a 95 civic ex with the d16z6. My thermostat is currently stuck shut and I hope thats all thats wrong with it. My question is when I change it out would a hotter thermostat make a noticable difference in FE? I've read that a 190 degree thermostat is better for FE but I don't want to push the head gasket any at all as my car has 240,000 miles.
Old 04-03-2013, 11:45 AM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
the savings in FE would be very small compared to the loss of the engine. imho
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 04-09-2013, 07:51 AM   #3 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I went with a VX thermostat on my high-mileage Civic. Slightly hotter, but obviously a Honda-approved temp. Partsgeek has NTC (OEM) thermostats cheaper than the dealer.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 04-09-2013, 10:09 AM   #4 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Does your head gasket leak already?
Old 04-09-2013, 11:06 AM   #5 (permalink)
It boils over into the overflow then evaporates. It uses a little coolant every day.
Old 04-09-2013, 05:25 PM   #6 (permalink)
That isn't a head gasket leak, that is a result of your engine already running too hot since the thermostat is stuck shut.
Your risk of blowing the head gasket is many times greater with your current problem than by running a 190 degree thermostat.
I'm no expert on the subject, but I can't see any reason why a 190 degree thermostat would appreciably affect gasket deterioration. There is practically no added pressure since it isn't a boiling temperature. Perhaps the material is slightly weakened by the extra heat, but it should be built to withstand much higher temps.
Old 04-09-2013, 05:46 PM   #7 (permalink)
I replaced the stat already but im wondering if its a bad one. I will swap it out again and make sure the next one works before I put it in. Is there a certain autozone stat thats better than others? I know original honda parts are the best but I need a quick fix till I can get an oem one from honda.
Old 04-09-2013, 05:54 PM   #8 (permalink)
You can check the t-stat by feeling the radiator hose. If the upper hose is warm to the touch after you've been driving a while, then the t-stat is open. If it's cold all the time, the t-stat is closed.
-soD
Old 04-09-2013, 06:04 PM   #9 (permalink)
You should also see the temp gauge go up if the t-stat is stuck closed. I've always purchased the cheapest t-stat I can find and haven't had any problems.
It is unlikely that you had 2 bad t-stats in a row that stuck shut, but I suppose it's possible.
Old 04-09-2013, 06:05 PM   #10 (permalink)
-soD
Do you mean the lower hose? Before the lower hose was cool and the top was hot. Now they are both hot. I'm wondering if the lower is hot from the temp under the hood. Its. It's not as hot as the upper is. Also would a stuck stat cause the fan not to come on? I haven't seen it come on yet since I've been driving the car. The sensor is right after the stat correct? So if its closed then it wouldn't know when to come on?
