Old 07-05-2008, 09:02 PM   #1 (permalink)
Honda Element 2 front end mods
Well, nothing fancy - grill block and I blocked off 2 gaping big recessed areas where fog lights are supposed to go.
I used vinyl clear stuff from walmart $0.84
for the upper grill I took off a few plastic grommets under the hood and slipped the vinyl under folded it over so it aimed out the front, but the grommets back on and shut the hood. Then I used clear silicon to create a seal around.
then for the fog light holes, same vinyl and clear silicon.
I'll have no idea if this does a darn thing, but I'm going on a road trip next week, and I'll check my milage generally. previously with no modified driving style I was getting 24mpg going 75mph.
With driving 65 and with these 2 items, maybe 28 or 30? we'll see. I'll also have a bike on the roof, so that will be a big negative effect.
I really want the 6th gear! the element spins over 3000 at 60mph. Dumb!
Old 07-05-2008, 09:06 PM   #2 (permalink)
VW beetle
While I was at it I put some black duck tape on the inlet on the VW. who knows that that will do.
I already get 40-45mph when I drive the Beetle to work 10 miles on back roads, just from hypermiling basics like DWB and pulse and glide. (I don't do Engine off coast).
Old 07-24-2008, 04:58 PM   #3 (permalink)
Work looks nice and clean! Let us know how it turns out at the pump.I have a friend with an Element,and she'll be eager to hear your results.Good luck!
Old 07-28-2008, 10:34 PM   #4 (permalink)
30mpg
well, seems I got 30mpg on a trip from VT to NYC. I also modified my driving with neutral coasting, and driving 65 or slower, and higher tire prewsue
so who knows if this helped or how much. wish it was more scientific.
Old 07-28-2008, 10:55 PM   #5 (permalink)
bryn's Avatar
sputnik - '93 silhouette
90 day: 23.23 mpg (US)
home sweet home - '92 clubwagon E-350 xlt
very excelant - '92 civic vx
next time if you can keep the bike on the back, or better yet inside. that would help alot, but you knew that allready
Old 07-29-2008, 06:13 AM   #6 (permalink)
You're right! I actually ended up not taking my bike in part because I knew it would mess up my experiment.
I'm still happy with 30mpg on a 600 mile trip with some a/c running. Better than the typical 24 when I set cruise on 75.
Thanks for the comment
Honda element, vw beetle, jeep wrangler... hans2vt Introductions 9 05-08-2009 04:05 PM
Aero Front End Possibility? Coyote X Aerodynamics 12 06-07-2008 12:43 AM
Honda Insight (potential mods for reduced drag?) donoman Aerodynamics 20 03-24-2008 07:59 PM
Honda front spoilers bestmapman Aerodynamics 6 02-24-2008 10:52 PM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
