Old 03-26-2009, 01:03 AM   This thread is in the EcoModder Project Library | #1 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Hot Air Intakes..
If you have a scangauge and a hot air intake, what is your outside tempuature as well as your incomming air temps? (read from MAP sensor)
I'm building a hot air intake and would love to see some pictures of everyones setups..
I'd attach my pics for archiving purposes but the
file size limit is too tiny to make it worth while..
Old 03-26-2009, 01:28 AM   #2 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
Chris D. -
It varies based on the weather and traffic, but with my HAI setup and grill block, it's almost always over 120 degrees F. Today on the freeway, with an outside average temp of 70+ degrees F, I was able to average over 130 degrees F. I think it was even higher, maybe 140+, but I forgot to watch it closely today, .
If I can find some time this weekend I will take it out and take some pictures.
If you can make your JPEG just under 100K, then you can upload it without being rejected. I can change the JPEG compression using Paint Shop Pro, so I mess with the compression until my chosen image is just under 100K.
CarloSW2
American Solar Energy Society
Old 03-26-2009, 08:35 AM   #3 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Here's mine for the elantra.
Seeing 50 to 80 F over outside temps with 80% blocked front grille.
www.HyperKilometreur.com - Quand chaque goutte compte...
The Following User Says Thank You to tasdrouille For This Useful Post:
mcrews (04-01-2010)
Old 03-26-2009, 05:14 PM   #4 (permalink)
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
Thats a nice HAI.
Old 03-26-2009, 05:16 PM   #5 (permalink)
Weight Reduction
Drive Stick's Avatar
neon - '95 neon Highline
90 day: 37.7 mpg (US)
Subaru - '98 Legacy L Wagon
90 day: 29.94 mpg (US)
Saab - '98 900 S
90 day: 51.25 mpg (US)
Impreza 2.5i - '011 Impreza 2.5i
90 day: 24.06 mpg (US)
Send a message via AIM to Drive Stick
I just posted about mine actually, outside is 46° today, intake at idle was 140° and @ 2,000 rpms it was 126° off-load.
I used a temp sensor on my digital multimeter it's somewhat accurate. See thread for photos
_ Brett
Old 03-27-2009, 01:36 AM   #6 (permalink)
EcoModding Minded
Chris D.'s Avatar
Originally Posted by cfg83 View Post
Chris D. -
CarloSW2
I was able to upload the same exact pictures on my
other forum that has a limit of 97.7 KB for jpeg pictures..
I believe they have their upload setup to auto resize automatically no matter what the size..
Old 03-27-2009, 01:49 AM   #7 (permalink)
EcoModding Minded
Chris D.'s Avatar
ok, heres what I've got so far..
heres the stock setup..
new intake tract setup I chose to use to make room near the manifold..
I used the tubing from a K&N Intake setup..
It wasn't intended to use the factory airbox..
heat gun, dremel, ect..
This is a deck plate lid.. they use these on boats..
It has a water tight screw in cap that I've left open..
for now it sucks in under hood air with a grill block..
I shoved a rag in the opposite side of the airbox where the cold air came from through the fender..
I'd love to figure out a setup so I can switch back to cold
air (on the fly) so i don't detionate if I need to get on it..
I'm still workin on this, not completly finished yet..
What I'd like to see are peoples results in tempuature and what
the outside tempuature was at the time your intakes temp was measured...
heres pictures of how I installed the deck plate..
I also cut some of the stock intake on the cold side to make a little more room
skuffed it up.
washed it out.
epoxy
screwed/glued
inside view with cover in..
finished setup..
so that little 3" tube was clogged up with a rag as you've
already seen to put it in perspective in the engine compartment
Old 03-27-2009, 07:58 AM   #8 (permalink)
Moderator
Very nice Chris, it doesn't get much simpler than that when you want something you can turn on and off at will.
Old 03-28-2009, 01:17 AM   #9 (permalink)
EcoModding Minded
Chris D.'s Avatar
I'd like to have a setup that'll switch from hot to cold air
intake with the flip of a switch or due to a lack in vacuum..
I remember talks of using a volvo air box but nothig came of it on the thread.
Old 03-30-2009, 09:18 AM   #10 (permalink)
That is exactly how mine is setup, hooked to manifold vacuum. Low vacuum equals CAI and high vacuum equals WAI/HAI. A3 (1993-1999) VW 2.0L air box has dual inlets and a vacuum controlled flapper to switch back and forth.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 10:30 PM
Hot Air intake vs. Cold Air... why or why not? Blister General Efficiency Discussion 3 10-09-2008 11:01 AM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 11:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 04:24 PM
A New 'Take' On Hot Air Intakes Funny EcoModding Central 18 04-11-2008 08:23 PM
