Old 05-04-2011, 12:44 PM   #71 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
#1 is the correct way to do things. If its not starting, the only thing I can think of is that you need to let the cutch out a tiny bit more to spin the engine up a little faster.
Old 05-04-2011, 12:46 PM   #72 (permalink)
Black Magic - '96 Civic HX
90 day: 46.37 mpg (US)
Ok cool. So then back to my original question: Why is it better to do it that way?
Old 05-04-2011, 12:51 PM   #73 (permalink)
CM400E - '81 CM400E
Better than your #2 way of starting? Mostly because its easier and can be done with less distraction from driving. But, by just brushing the clutch against the flywheel, and then rev matching, you have less clutch wear too.
Old 05-04-2011, 12:57 PM   #74 (permalink)
Okay thanks. I will play around with it again and see if I can get it working better. I am keeping it in high gear not going super fast so the rev match point isn't all that far above idle anyway, but I will shoot for optimal.
Old 05-10-2011, 01:29 PM   #75 (permalink)
Aero Sol - '93 Del Sol GSR
90 day: 40.31 mpg (US)
Less wear on your ignition system (ie. starter) and your "keyhole" mechanism.
It also uses less gas to bump start because you can fire up the car without the need for the fuel injectors to squirt fuel.
Old 05-24-2011, 02:34 PM   #76 (permalink)
Good tip! Been using this method to start when my battery is dead for a long time.
bump starting, clutch starting
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
