Old 07-12-2009, 02:55 PM   #51 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Originally Posted by taredog View Post
Most of us have single piston calipers. It is very important that the caliper can move on it's mounting bolts. What did the inside pad and the other side of the caliper look like? May have been rust plus a frozen caliper problem.
I didn't specifically check the slider pins / calipers, but I don't believe it's the problem. (Based on pedal feel & stopping ability seeming normal).
When I get back on land next month, I'll sort out the brakes and all questions will be answered.
Old 07-13-2009, 10:32 PM   #52 (permalink)
Trucking-Modder
SmallFry's Avatar
Big Truck - '08 Prostar
What is the comparison of costs of replacing the brakes vs. mpg/money saved? Allegedly, I try that in my big truck when I'm empty or light and not in heavy traffic. GA overdrive @ 600 rpm is better than 0 trottle at 15-1600 rpm, right? And another thing I've thought about is that it's cheaper to replace the brakes earlier than expected because the fuel savings far outweighs the brake loss.
Old 07-15-2009, 11:40 AM   #53 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
Originally Posted by captainslug View Post
WD-40 is not a very good lubricant. It's a strong degreaser and water-displacer.
I was going to go there, you beat me to it. WD-40 does a decent job as a penetrant, and is okay - not great - as a water displacer. It's my first choice for shooting into cracks and stuff, but that's only until I can get parts loose. Then I reach for grease or something else that'll actually stay around for a while.
As to shooting it onto brake discs, I wouldn't be too concerned if it was done, but I'm not about to go doing it on purpose, either.
You're not in front of me...
I'm 25,000 miles in front of you.
Old 07-16-2009, 01:23 PM   #54 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
Not to place more fuel on the fire, however, I remember reading somewhere that the brake pads themselves contain a certain amount of solvents and volatile chemicals that dissipate during the first 500 or so miles of use. Therefore, shouldn't the small amount of WD-40 being applied to the ROTORS (not applied directly to the pads) burn off with very little effort, possible not contaminating the pads? Never had a problem with rusty rotors on my daily driver, nor have I driven a car that had a freshly applied coating of WD-40 on the rotors, so I can't speak for that experience. However, I did use WD-40 on my Rx-7 rotors when I stored it over two winters up here in MA for six months at a time, and when I took the cover off in spring, whaddayaknow? No rust both times, maybe the WD-40 needs adequate time to age.. I also never clean off the anti-corrosion coating when I change the rotors.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 07-16-2009, 03:49 PM   #55 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I think the "adverse effects" of having something like WD40 on the brakes are being blown out of proportion.
Right now I have bad axle seals on my F150 and the shoes are oil soaked (for some reason I am resisting tearing into that project). Yes I can tell the difference between oil-soaked and dry when I'm driving it but really the difference is quite small. It stops just fine, and I suspect if I had to stop hard it would do that just fine as well. If someone else drove that truck and they didn't know about the oil I bet they wouldn't even suspect a problem.
I think a big factor is loading. We typically are very lightly loaded when going about the daily grind and the brake system isn't being taxed much. Load heavily and it becomes more of a factor.
Bottom line is IMHO no harm can come from some WD40 or some such on the rotors; it probably burns off pretty quick.
Old 08-14-2009, 06:02 PM   #56 (permalink)
Picked up my new pads & rotors today. $100
Chose premium pads only because several people told me they had bad experiences with economy pads (wearing early, noise, brake dust). The parts counter guy wasn't helpful in determining the difference between the premium, mid-grade & economy choices. "Might even be the same ones in different boxes." Made in Italy.
Oh well. Somewhere a marketing hack is smiling.
Chose the economy rotors. $2 more than machining the factory discs (which I'll keep and have machined if these new ones turn out to be worse in any way). Made in China.
Should have a chance to install everything, grease the caliper sliders, and bleed/replace the old brake fluid on Sunday.
Old 08-14-2009, 09:43 PM   #57 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I always get stuff with lifetime warranties, regardless of supposed quality issues.
I've been warned against it how ever many times, but I've never had a problem with any of it, and even if I did have a problem, I'd just take it back for the warranty. LOL.
I even get lifetime warranties on my brakes and related parts. I've not had to pay for more than one set of brakes on any car that I've owned/worked on.
One of those ways that I make an extra buck on return work - get the lifetime warranty the first time, then when they come back, it's the same price for them, but I get the parts free.
New personal record: 632 miles on 1 tank. 48 MPG in my Auomatic 05 Corolla blackjackel Success Stories 6 11-30-2009 01:02 PM
