Old 06-10-2011, 02:57 PM   #1 (permalink)
Hauki's Avatar
Scudo - '98 Fiat Scudo (van) 1.9 TD
90 day: 40.94 mpg (US)
Stealthy Grille Block
I found some cheap plastic in the basement today so i thought I would make a prototype grille block until I get some polycarbonate/perpex and do it properly.
I was going to attach it the front, but the grille mounting bolts behind made it very easy to attach and it makes it more stealthy.
I had a quick run out to the shops in it, temperature didn't go any higher than usual, but to be fair I only done 30MPH. I think (& hope!) the engine temp will rise a bit once in 5th gear and doing 50-60mph, because now I am at 88°C and the fan doesn't come on until 102°C, so I have a lot of room to manouvre.
I haven't had chance to check if it affects FE. But this and my lower grille block installed the other day should hopefully yield some results.
Goal: 5 L/100 km
Currently:
Car Spares
The Following User Says Thank You to Hauki For This Useful Post:
mcrews (06-10-2011)
Old 06-10-2011, 03:32 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
vere nice!!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-11-2011, 10:49 AM   #3 (permalink)
Hauki's Avatar
OK today I went for a run and kept an eye on temp gauge.
Just to refresh, I have blocked both upper and lower grille on the car now so there is none/very little airflow coming through to the rad.
Today was a hot one, it was 31°C (88°F), it very rarely goes above 33/34°C (93°F) so I could pretty much judge today if I could run year round with these blocks on.
My temp gauge went to 98°C (208F) one way, 96°C (204F) on the way back. I didn't employ any hypermiling techniques as I wanted constant load on the engine for accurate temps. The fan comes on at 102°C (215F) on my car so I would say averaging 97°C on a sweltering hot day like today is pretty much a success.
I hit 45MPG / 37.5MPG (UK/US) without using any hypermiling, this is a new record, but not until next weekend and I travel to the city 50miles away will I get a clear picture of just how effective it is where this route is where I do my calculations on every time.
But for me, this is what it's all about
I hope it's still this fun when there is no improvements to be made and you just take your great milage for granted.
Goal: 5 L/100 km
Currently:
Car Spares
Old 06-11-2011, 11:10 AM   #4 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Enviable result. My fan goes on at something around 208F. And even in cooler weather, with only an 80% block my fan turns on.
