Old 10-30-2011, 10:16 PM   #31 (permalink)
Originally Posted by ConnClark View Post
Perhaps you need to read this thread or at least look at the picture before thinking about moving a lithium ion pack into your passenger compartment.
Why you shouldn't mess with lithium ion
Somehow I don't think you have a computer handling the charging to do it safely. Keep in mind even with one these things can still go off.
Straight trippin fool. I hope you leave your lap top and cell phone outside the car too.
Old 10-31-2011, 12:25 AM   #32 (permalink)
www.howtobuildahybrid.com
ncwa's Avatar
Headway LiFePO4 Starter Battery
I pulled my 36lb lead battery out of my ‘66 Mustang and replaced it with a 16 Ah custom Headway LiFePO4 pack and BMS (total weight of 4 lbs!). This was a great solution but only worked well for about a month. Over time the battery started to loose cranking amps and eventually it would not start the car. At the time I was having a little bit of trouble with my low voltage relay so I might have dropped below the 2V min limit. I have since switched back to lead. However rather than the original 90 Ah battery, I am using a smaller 45 Ah 19 lb battery. This has been working well but I do keep a close eye on its charge. I think this would work for a smaller engine in a warm climate. (As a disclosure, the Ah rating of my battery is not as critical as I also have a 25 amps coming from my DC/DC converter and I can practically start the car with my e-drive if needed)
Old 10-31-2011, 11:26 AM   #33 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
My lithium battery pack is still working good after about 3 weeks of use.
My battery pack is in the back seat and has a forklift QD so I can pull it on cold nights. Usually when I bring it in I top it off with a lead acid battery charger set for "deep cycle".
On the 2 amp slow charge it never draws power for more than 10 minutes.
One cold morning when I left the battery in the car it didnt want to do an extended cranking cycle on my car to prime the carb bowls. I need to convert to an electric fuel pump so I dont have to use the starter motor to prime the carb.
I am also going to check for voltage drop on the new wiring to include the grounds.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
Old 01-19-2012, 07:53 PM   #34 (permalink)
EcoModding Newb
Acura TSX - '06 TSX
90 day: 29.95 mpg (US)
Lafawnda - '01 CBR600 F4i
90 day: 43.18 mpg (US)
Jeep - '02 Liberty Sport
90 day: 18.02 mpg (US)
I understand that Li batteries can be discharged deeper than lead acid without causing permanent damage. Can this be done on a regular basis, and what depth of discharge can safely and routinely be achieved?
I'm wondering if I could swap my battery for a lithium and run my car in alternator delete mode while charging the battery every night.
What are your thoughts on running a minimal hassle alternator delete? My daily commute is about 15mi round trip, with weekend commutes of 70mi 1 way.
Old 01-19-2012, 09:28 PM   #35 (permalink)
V8 guy
Pickups
LiFePO4 batteries can be discharged down 80% where deep cycle lead acids like it about 50% deep and lead acid starting batteries can only take about 15% to 20%.
redpoint5 (01-19-2012)
Old 01-22-2012, 07:59 PM   #36 (permalink)
V8 guy
Pickups
Oh and I plan on using a LiFePO4 battery in my truck now that I have added some more 1990s tech to my suburban.
After installed the gear reduction starter my truck will fire up with my camaros 20 cell LiFePO4 battery.
DIY: BYOB, for more power, a lot less weight - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Old 02-03-2012, 01:47 AM   #37 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
Ebay. They are 4x2 and 4x3. 100 or 130 dollars. Look up motorcycle battery A123.
Old 02-22-2012, 08:32 PM   #38 (permalink)
V8 guy
Pickups
My trucks lead acid starting batteries have gotten surprizingly weak all of a sudden, the LiFePO4 conversion may happen soon than I thought.
At the start of last winter I thought they might have a year left, looks like I was wrong.
For the truck I plan on constructing a 4x13 A123 pack.
Old 03-23-2012, 03:59 PM   #39 (permalink)
V8 guy
Pickups
Well my batteries were acting a little weak again, tried charging them like I did on the 22nd of feb, but today they wouldn't charge.
LiFePO4 batteries are on order.
Old 03-23-2012, 05:49 PM   #40 (permalink)
Black Knight - '94 Corolla
90 day: 61.92 mpg (US)
good luck, report back and take pics.
