Old 04-02-2018, 12:46 PM   #1 (permalink)
Smokey - '13 Chevrolet Cruze Eco
Liquid cooled/warmed oil filter mount?
I saw a post on a Miata site of someone puting this mount off an Alfa 164 on his Miata. It has engine coolant running through the oil filter mount. Anyone use this mod?
Old 04-02-2018, 12:51 PM   #2 (permalink)
A lot of the high mileage spec cars do like the Civic VX, HX, and the Honda Insight. It doesn't seem to be a popular add on item though.
Old 04-02-2018, 01:05 PM   #3 (permalink)
90 day: 40.51 mpg (US)
The oil heat exchanger was removed for later years of the Insight. I haven't read much on it doing much of anything. I suppose it should help the oil to heat up more quickly?
Old 04-03-2018, 08:00 PM   #4 (permalink)
Eco Storm Chaser
Stacygifford's Avatar
Nemo - '87 Ford Mustang GT
90 day: 27.26 mpg (US)
K-sight - '02 Honda Insight
90 day: 39.24 mpg (US)
You could possibly use something like this from a Subaru Forester and can be had quite cheaply from a junk yard. As long as the thread pitch and size is the same size, it should work for a number of applications.
It simply screws in place between the oil filter and the block.
