Old 02-03-2011, 05:14 PM   #1 (permalink)
SVTwithMPG's Avatar
El Diablo - '03 Mustang Cobra
Crapolier - '98 Cavalier base
90 day: 34.81 mpg (US)
Made a bumper block today(pic) and have a couple ?s
I made this today from a strong, flexible, semi transparent plastic. I got it from work (free). My car suffers from a very long warm up time in the winter. I'm hoping blocking the main source of air will improve warm up.
Was this a better choice than blocking the space between the bumper and hood? I could easily do that as well.
My only other mods are 52 psi in the tires, mudflaps and antenna removed.
Feel free to pick apart my cavaliers aerodynamics, I read the drag coefficient is .36 which amazes me it's so much worse than my cobras .32 (in avatar).
Thanks,
Michael
Old 02-03-2011, 09:58 PM   #2 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
If that's packing tape you used to secure it on there...don't count on it keeping it on there very long...maybe a couple of weeks before the weather/sun degrades it to the point where it will fail. Maybe you can use the front license plate holders to screw the panel on?
The Following User Says Thank You to BamZipPow For This Useful Post:
SVTwithMPG (02-09-2011)
Old 02-03-2011, 10:01 PM   #3 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.96 mpg (US)
Looks really good. The percentage of open grill is similar to what I run on my Civic in winter - so I suspect it will work well in the cold season.
Come March or April, I can't continue to run a full lower block. I remove it bit by bit untill the radiator is completely unblocked by summer. My grill block isn't nearly as nice looking as yours, or as aerodynamic though.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Old 02-03-2011, 11:00 PM   #4 (permalink)
SVTwithMPG's Avatar
It's a little stronger than regular packing tape, but you are right, not long term. The blue plastic has an adhesive on it also. If all goes well I'll cut one out of lexan and use the plate holder. It won't look so ghetto then.
