Old 01-28-2017, 11:41 PM   #211 (permalink)
ScanGauge <3
ThermionicScott's Avatar
*bump*
This isn't about one of the 65+ ecomodding tips directly. I notice when viewing the page, the "topic" icons and some of the thread links don't work. I wasn't around for it, but I gather there was a forum software migration that changed all the paths from "forum.ecomodder.com/" to "ecomodder.com/forum".
The topic icons are coded as "http://forum.ecomodder.com/images/em-skin/statusicon/forum_new.gif" but changing the path to "http://ecomodder.com/forum/images/em-skin/statusicon/forum_new.gif" works. I think the same issue is at work in the 100+ hypermiling/ecodriving tips page.
Meddlesome software engineer signing off...
- Scott
Best tank (so far): 32 MPG
The Following User Says Thank You to ThermionicScott For This Useful Post:
Daox (01-29-2017)
Old 04-03-2017, 01:03 AM   #212 (permalink)
ASV
weirdo
ASV's Avatar
Ok so a mod that has been well documented and tested and can bed done in a backyard.
How about replacing smooth v belts with cogged or notched v belts
There is well documented efficiency gains to be made
And if not done yet is really lo hanging plum
Old 07-12-2017, 09:36 PM   #213 (permalink)
I suggest adding converting to LED lighting for headlights, taillights, reverse lights, turn signals, brake lights, licence plate lights, dash lights, etc to the list of 65+ mods for improved efficiency under the electrical section. When I converted my headlights, taillights, license plate lights and parking lights on my 2005 Civic to LED, I noticed that turning on the headlights no longer bogs down the engine at idle. I then converted to all LED lighting. As for a mileage increase, not sure, but it definitely didn't hurt
The Following User Says Thank You to EcoCivic For This Useful Post:
YukonCornelius (06-10-2018)
Old 06-10-2018, 04:03 PM   #214 (permalink)
Exceptional Member
YukonCornelius's Avatar
Crapolier - '98 Chevrolet Cavalier base
90 day: 34.81 mpg (US)
05 CTS-V - '05 cadillac cts-v
90 day: 33.01 mpg (US)
95 Accord - '95 Honda Accord
90 day: 38.06 mpg (US)
11 CTS-V - '11 Cadillac CTS-V
Another free mod. Disabling Day Time Running Lights. On some cars it's as simple as pulling a fuse. I know on my GM's they run the high beam halogens at reduced power for this.
Don't know why it says 00, it's a 95
374,000 miles and tired.
Old 06-11-2018, 12:14 AM   #215 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Check your local laws first, though.
Old 06-11-2018, 04:00 AM   #216 (permalink)
Exceptional Member
Sorry, I was only considering the United States. Very American of me.
https://www.quora.com/Why-arent-day-...s-in-the-world
"As recently as 2008, the National Highway Traffic Safety Administration concluded there is no evidence that DRLs provide enough of a safety benefit to require federal regulation. And there’s no sign it will change its mind in the future."
Old 10-22-2019, 03:56 AM   #217 (permalink)
just joined..
Civic - '15 Honda Civic Tourer SR
here's one i didn't see on the 65+list: set wheel alignment to factory (or zero/ straight ahead).
my honda had wheel alignment way out of spec when i bought it (3 yrs old, used car). re-set to factory alignment improved economy.
i would expect going to a zero toe set up might improve economy even more.
Also, what about re-mapping? Is that on the list? My honda get better mpg with an aftermarket engine map.
I'm also going to look at the potential for some economy gains in re-designing factory exhaust systems - maybe removing some of the restrictions there might give me some gain for not much $£.
The Following User Says Thank You to rob.e For This Useful Post:
Gasoline Fumes (10-24-2019)
Old 10-22-2019, 10:43 AM   #218 (permalink)
90 day: 29.44 mpg (US)
There are zero-toe discussions on here, but I have not seen them in years. I asked for one when I took my car for an alignment, but they refused.
Should I have called around until I found a cooperative shop?
They say that with zero toe it takes much more effort to keep your car centered.
Old 10-22-2019, 10:57 AM   #219 (permalink)
just joined..
yes that's why i put mine to factory (correct) settings first to see if that improved things.. i have the option if i want to go for zero in the future. tbh car is lovely in a cruise right now, tracks perfectly straight with no input so i don't really want to mess that up
Old 10-22-2019, 11:05 AM   #220 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
I have seen discussions on this, and have some of my own personal experience in this subject. A forum member suggested a slight toe in for both front and rear wheels, as the suspension is not completely rigid. So I did my own alignment at a shop and set all 4 wheels at 0.01" toe in. I really have to stay on top of steering on the highway as the car will easily change direction. On the highway when I accelerate, the car tends to wander, which tells me that the very small toe in turns to zero or toe out. A slight amount of tire scrubbing from toe in is probably a better choice than having zero toe and a car that constantly needs to be corrected. Those corrections aren't free either.
Knowing what I know now, I will get my next alignment done with 0.02" toe in on the front, and 0.01" toe in on the rear.
Depends on the car, but yes you should have. My car had a range of 0.08 to -0.08" of toe, so zero toe is already in spec. Yes it does take more effort to keep the car centered.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
The Following User Says Thank You to Daschicken For This Useful Post:
Xist (10-22-2019)
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 10:53 PM
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 318 01-19-2015 11:37 AM
Pulse&Glide, and aero mods, big mpg increase. Sulfuric Success Stories 3 01-15-2009 11:57 AM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
