Old 09-11-2009, 02:36 AM   This thread is in the EcoModder Project Library | #1 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 43.34 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 106.98 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
Thumbs up My Aeromodded Civic Bumper
I had a spare front bumper for Thrifty McGassaver (my VX) and this is what I've done with it so far:
Done with the help of a buddy of mine that I work with in the summer. Took about 20 hours to get to this stage. Next up is a lower lip air dam.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 09-11-2009, 02:42 AM   #2 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Damn... that looks nice.
Any way (not that you'd want to now) that you could move the air inlet to the middle, and use the plate as a high-speed grille block?
Or even block the bumper's grille altogether, and use a pan-scoop under the plastic bumper cover to scoop air up into the radiator area... Again, not that you'd want to now.
That bumper cover looks sick, though. Great work.
Did you ABS-weld it, or just add FG, or is the whole thing FG/CF?
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
The Following User Says Thank You to Christ For This Useful Post:
TomO (09-11-2009)
Old 09-11-2009, 02:44 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
*jealousy*
Old 09-11-2009, 03:12 AM   #4 (permalink)
That VX guy!
TomO's Avatar
Took an OEM bumper and filled with Great Stuff foam, shaped foam, then fiberglass jelly'ed for a hard surface, sanded and shaped the jelly and then Bondo'ed for a smooth finish.
All in all I will plastic weld my next one I do this winter. It will end up being less work and better results. There is a touch of separation on this bumper already.
I made this bumper for use in winter here in MN. I like the results so much though that I will be doing something similar with my summer bumper.
The inlet is on the side because that is where the radiator sits in my Civic. The factory block off is still intact next to the radiator as well so I just made the opening over there, similar to how my summer bumper is setup but you can't see the opening on my summer bumper. I have a grill insert that hides the Coroplast grill block.
I had thought about closing up the whole front since I'll be using it for winter, but after it snows a little, the opening will get packed up with snow anyways, lol.
And Ben, don't be jealous, we can do something like that for your CRX bumper too once you get done with your swap.
Old 09-11-2009, 03:23 AM   #5 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I like it.
I like the psychedelic plate- I have a t-shirt kinda like that!
TomO (09-11-2009)
Old 09-11-2009, 05:16 AM   #6 (permalink)
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
VERY nice! It'll be interesting to see the reaction from ricers. First they'll see the carbon hood and think you are a ricer. Then they'll see the bumper and look confused! Excellent!
ollie
Old 09-11-2009, 10:23 AM   #7 (permalink)
That VX guy!
TomO's Avatar
ollie
They all think that I want to race, even after I had put the giant MPG stickers on the back and side of my car.
Old 09-11-2009, 11:24 AM   #8 (permalink)
pgfpro's Avatar
Very nice work!!! It looks like its a stock Honda FE bumper. If there every was a thing? j/k
Old 09-11-2009, 01:00 PM   #9 (permalink)
That VX guy!
TomO's Avatar
Closest thing Honda had was a factory grill block that stuck in behind the grill slats and I guess putting in the stock fog lights since that would fill the holes on the sides of the bumper.
It would be super cool if Honda had offered a bumper like this from scratch. But then the drag racers would jsut have one more reason to molest a perfectly good VX, lol.
Old 09-11-2009, 03:39 PM   #10 (permalink)
If the bumper is made of ABS (I can't remember) you can use Acetone to melt pieces in a cup. They'll turn to sludgy paste, and then you scoop that out and slap it on the seams, agitating and letting it dry, so the Acetone melts both surfaces and eventually they all mix together w/ the filler.
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 34 10-10-2011 11:01 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Wanted: Civic HX 4 replacement or Civic shell needing an engine HDCaptain For Sale 1 03-14-2009 03:57 PM
Any guesses on '83 Civic mpg? Ryland General Efficiency Discussion 7 07-12-2008 10:40 PM
advice - Jeep under bumper something? hans2vt Aerodynamics 6 07-07-2008 04:16 PM
