Old 10-23-2009, 06:04 PM   #11 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
..but, was the "final" Scientific Method criteria (ie: Repeatability) been done?
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SIDI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
Old 10-23-2009, 06:44 PM   #12 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Originally Posted by botsapper View Post
Ecomodders want more performance...from dimples. The golf industry knows when you have a good thing & wants more distance & less drag... just add more dimples!!!
Power Distance Golf Balls - The Freak - Best Golf Ball for Distance from Top-Flite Golf
Given the proper speed, a smooth sphere can go farther than a dimpled sphere. It all depends on the Reynolds number. The ball that would go farthest for an average lady does not have the same dimple design as the one that would go farthest for a pro long distance driver. The ball that goes farthest would be the one with dimples adapting themselves to the surface airspeed.
In theory dimples could work on some part of bluff bodies, but not to the extend they measured. Especially since they dimpled everything. It makes no sense whatsoever to dimple surfaces where the flow is laminar to start with.
I just don't like the way they tested it.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 10-23-2009, 07:29 PM   #13 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Insight
90 day: 98.7 mpg (US)
Well said. I agree 100%.
If dimples are to be used, they should be placed where the body shape drops away from the airstream too quickly, to energize the air in that location only.
You don't need to energize the air in places where it is still attached.
And any device that creates a small amount of turbulence would work. There's nothing special about dimples. Look at the numerous airplanes that have vortex generators on the wings to improve the stall characteristics.
Jim.
Old 10-23-2009, 07:55 PM   #14 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Looking at the results, they were doing something right.
I wrote in another thread how that Audi has dimpled plates on the undersides of some of their cars ( ironically, the dimples seem to be the same diameter as those use in the Mythbusters test ).
VW also had some of their cars with the dimples as well, and who can forget the well publicized dimpled underside of the Lexus LS-430 ?
I doubt any of us want to have huge dimples in the sides of our cars, but the undersides of our cars seem like a perfect place to have dimples.
Old 10-23-2009, 08:18 PM   #15 (permalink)
PSmodder lurker
botsapper's Avatar
True, a smooth ball could have a lesser force barrier but that critical speed is attained @ 300+ mph, but a dimpled golf ball passes its critical Reynolds number and with a smaller drag tail @ 55 - 300mph. This is within the practical ranges of a stroked golf ball, struck by a 40"+/- golf club, & within a 4 degrees from tee level, initial launch speed of 160+ mph, consistent backspin and resultant Magnus force lift. A dimpled golf ball creates beneficial lift & stays aloft longer, thus travels longer. The configuration would take all of the advantage of the smaller drag resistance @ the most of its flight. Tests indicate greater lift on spinning dimpled golf balls but even non spinning dimpled golf balls still have lower drag tails compared to spinning/non spinning smooth balls.
Zipp dimpled bicycle wheel covers have shown very good Reynolds numbers compared to smooth ones. It only begs for ecomodders to now use & favor 'dimpled' wheel covers over smooth ones. Another one on the 'must' list.
http://www.zipp.com/_media/pdfs/tech..._the_edges.pdf
Old 10-23-2009, 09:25 PM   #16 (permalink)
...beats walking...
...similar "smooth vs. rough/dimpled" analogies exist in the animal kingdom too, with the skins (actually cartlage-scales) of dolphins and sharks.
...smooth surfaces aren't always the "least" restrictive in the ocean either!
Old 10-23-2009, 11:19 PM   #17 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
White Pony - '07 Mustang V6 Premium Coupe
Team Ford
90 day: 29.22 mpg (US)
Big Red - '89 F-250 4WD Custom
90 day: 15.34 mpg (US)
Most water skis I've seen have a "pebbled" running surface. And most of the wake boards I've seen have dimples in the running surface.
FWIW.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Old 10-24-2009, 12:12 AM   #18 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Originally Posted by ChrstphrR View Post
By the other thread, you mean the one about the perforated vinyl film?
Apples and oranges, Chris.
Adam and Jamie ran each test 5 times through for each variable, took measurements, using a reproducible method. They did take care to try and control other factors to isolate the effect they were looking for:
- Separate fueling systems for the measured interval
- Measuring/weighing the alternate fuel supply to determine consumption
- Only measuring the above at a constant, uniform speed each run
- Measuring across the same length of road for all runs
What was elided from the show, that may show any major or minor variations:
- Actual run data not published for all to see (sure looked like they recorded it, though)
- It's not known what the weather/wind speed and direction were, and if that fluctated, which could perturb testing runs
Atop that, they ran through models to see if there was an effect appreciable enough to bother testing full scale.
What are you actually trying to poke holes in, with what they presented?
No, I meant the other thread about this very topic.
"Ώʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux κtre heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 10-24-2009, 12:14 AM   #19 (permalink)
2001 ZR2 Blazer e85/gas flex
Old 10-24-2009, 12:21 AM   #20 (permalink)
...beats walking...
...ah, but the "aero"-hairdo dude definitely don't look very aerodynamic.
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/mythbusters-tests-golf-ball-dimples-10718.html
Posted By For Type Date
Need help for co2 car design? - Yahoo! Answers This thread Refback 12-15-2011 05:28 PM
EcoModder.com Latest Blog Posts This thread Refback 11-02-2009 01:47 AM
VIDEO: Mythbusters test golf ball-like dimpling effect on fuel economy ... This thread Refback 10-29-2009 03:29 PM
Hexagonal Dimples as a way to improve aerodynamics Palionu Aerodynamics 29 10-27-2009 01:39 AM
