Old 10-23-2009, 08:43 AM   #1 (permalink)
Mythbusters tests "golf ball" dimples
Admin note: 2 threads got started on this topic. Another discussion is here: http://ecomodder.com/forum/showthrea...oct-10658.html
Hi,
Yet another interesting test of an aerodynamic effect by Mythbusters (with video):
VIDEO: Mythbusters test golf ball-like dimpling effect on fuel economy (*Spoiler Alert!*) — Autoblog Green
Old 10-23-2009, 11:47 AM   #2 (permalink)
Schwartzejetta - '00 Volkswagen Jetta TDI GL
90 day: 52.87 mpg (US)
Hard to dispute their method and testing.
Makes me want to go out and get a Volkswagen Golf ... or *make* one
Current mod: Skidplate/Undertray for my MkIV Jetta. Next mod: CAD drawing for skidplate so other Jetta/Golf drivers can make one too!
Old 10-23-2009, 11:57 AM   #3 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
No, it's actually quite easy to dispute it. Go read the other thread on this same topic.
Old 10-23-2009, 02:10 PM   #4 (permalink)
By the other thread, you mean the one about the perforated vinyl film?
Apples and oranges, Chris.
Adam and Jamie ran each test 5 times through for each variable, took measurements, using a reproducible method. They did take care to try and control other factors to isolate the effect they were looking for:
- Separate fueling systems for the measured interval
- Measuring/weighing the alternate fuel supply to determine consumption
- Only measuring the above at a constant, uniform speed each run
- Measuring across the same length of road for all runs
What was elided from the show, that may show any major or minor variations:
- Actual run data not published for all to see (sure looked like they recorded it, though)
- It's not known what the weather/wind speed and direction were, and if that fluctated, which could perturb testing runs
Atop that, they ran through models to see if there was an effect appreciable enough to bother testing full scale.
What are you actually trying to poke holes in, with what they presented?
The Following User Says Thank You to ChrstphrR For This Useful Post:
shovel (10-23-2009)
Old 10-23-2009, 03:14 PM   #5 (permalink)
I think it's just human nature, law of conservation. It's easier to criticise than create.
Work From Home mod has saved more fuel than everything else put together.
Old 10-23-2009, 03:24 PM   #6 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
if they sprayed the car with aluminum mud (? just saying)
I wonder what would happen..
the point is cars are on rubber wheels, they use every inkling of their bodies for dispersal of energy created. all powers from coil, nuclears (never ever say never)from combustion, moleculars, hertz from the generators, and wiper motors and heaters, and...well that is my point.
a freshly high grade urethaned automobile respecting the cars system of origin will do as good as it can.
and for the golf ball thing..moving air as fast as possible to back to where it came from (a car plowing through the air) is as smart as it gets. That needs smooth. to our eyesight anyway. in reality, it is simply "micronically bumpy".
I fell for the golf ball dimple thing with a pc fan, the only benefit was demanding more draw because the fan was too light for the air (cheap product). I ended up reverting to the classic large paddled design that has been there since my first computers. It is all a crock.
including skirtings on the bottom of cars.
concerns for aero? you need a drivetrain. you need better bearings, higher grade grease, and better dispersal of energy created. aero is a silly product after conquering the other things. I sincerely mean it...
Old 10-23-2009, 03:51 PM   #7 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
I'm not sure how you can look at the results people like basjoos have had and say that. Unless I misunderstand you.
The Following 2 Users Say Thank You to KJSatz For This Useful Post:
PaleMelanesian (10-23-2009), robertwb70 (10-25-2009)
Old 10-23-2009, 04:08 PM   #8 (permalink)
So much for the kook-free thread... might as well let the HHO-philes pile on in now. :P
Old 10-23-2009, 04:41 PM   #9 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Exactly what I was going to say.
Old 10-23-2009, 05:02 PM   #10 (permalink)
PSmodder lurker
Ecomodders want more performance...from dimples. The golf industry knows when you have a good thing & wants more distance & less drag... just add more dimples!!!
Power Distance Golf Balls - The Freak - Best Golf Ball for Distance from Top-Flite Golf
Hexagonal Dimples as a way to improve aerodynamics Palionu Aerodynamics 29 10-27-2009 12:39 AM
