Old 06-25-2009, 12:23 AM   #1 (permalink)
Highlander - '06 Highlander Hybrid Limited 4x4
90 day: 25.88 mpg (US)
New Guy Driving Mom's Odyssey
I'm still in college, so please don't judge
Actually, I don't mind the Odyssey (2006 EX-L). My friends all try to make me drive when we go places. I have a suspicion it has to do with two things: leather interior and something called "leg room" that doesn't exist in their compacts...
Anyhow I'm trying to learn how to squeeze as many MPG out of the van as possible.
Old 06-25-2009, 01:08 AM   #2 (permalink)
UfoTofU's Avatar
Welcome, I'm still in college too
Old 06-25-2009, 01:16 AM   #3 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
Sovereign -
Welcome to EM! Are you your own country yet, ? Those moocher friends of yours better be paying for gas, or at least hamburgers! Have you been taking advantage of the cylinder deactivation? :
2006 Honda Odyssey EX-L Minivan reviews - CNET Reviews
There is a lot of clever technology in the 2006 Honda Odyssey EX-L's engine bay, which is not what you'd expect from a vehicle that seeks neither amazing gas mileage nor exceptional performance.
But the Odyssey EX-L's 3.5-liter, SOHC V-6 engine seeks optimal gas mileage through the use of cylinder deactivation, a much-maligned technology. Honda calls it variable-cylinder management (VCM), and it's standard equipment on the EX-L. By exploiting the controllability of Honda's VTEC valve train, engineers were able to devise a largely hydromechanical system to close and idle the valves and injectors on the rear three cylinders on this transversely mounted engine when the car doesn't need them.
CarloSW2
American Solar Energy Society
Old 06-25-2009, 02:29 AM   #4 (permalink)
Originally Posted by cfg83 View Post
Sovereign -
CarloSW2
How does one "take advantage?" I try to keep the green light on, if that's what you're getting at...
Old 06-25-2009, 02:44 AM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Sovereign -
Yep, that's it.
CarloSW2
Old 06-25-2009, 09:23 AM   #6 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Welcome to the site.
Definitely check out our 100+ hypermiling tips. You'll see your best gains there.
Old 06-25-2009, 01:24 PM   #7 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 72.37 mpg (US)
From driving my 2004, which doesn't have VCM:
- Keep the rpm low. Below 2000 for accelerating.
- Learn when the shift points happen. Let up a bit on the gas to encourage it to shift sooner.
- Once it's locked into top gear (45mph), do all you can to keep it there.
- You can hold it in top gear better on uphills than the cruise control can. I disable cruise for uphills and then reengage it when the flat land resumes.
- It's eager to engine-brake, so be ready with the shifter to drop it into Neutral for longer coasting.
- Any stop and reacceleration is going to cost you big-time, so do all you can to keep moving - timing lights for example.
- Pump up the tires. Balance comfort / noise against mileage, but definitely go a bit above the car's doorpost numbers.
Does it have an MPG readout? If not, Scangauge time! Seriously. In a thirsty beast like this, it'll pay for itself in short order, through driver training.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
"Hypermiler" pulled over for driving too slow SVOboy Hypermiling / EcoDriver's Ed 100 11-03-2009 12:11 AM
Any advice for driving by vacuum guage? video Chris D. Instrumentation 33 02-22-2009 12:54 AM
I took out a guy on a bicycle with my truck.. Chris D. The Lounge 16 11-01-2008 11:00 PM
New guy.. Driving 94 Rx7 dmhrx7 Introductions 10 10-30-2008 11:46 PM
EM Sticker contest #2: guess Mom's MPG! ('97 Camry 4-cyl auto) ends Sun., Feb. 3 MetroMPG Hypermiling / EcoDriver's Ed 33 02-04-2008 10:30 PM
