Old 01-22-2012, 08:32 PM   #1 (permalink)
new old eBay IGBT's
Hi,
(first post from longtime lurker who'll introduce himself wider when he has something more to contribute...)
Being interested in power section based on IGBTs rather than MOSFETs I keep my eye on eBay as a source of cheap modules; I'd like to know your opinion on Fuji's 1MBI600U4B-120. This is single transistor module similar to 1MBI600PX-140 IIRC used by jackbauer and etlaare. It's available from well-known-here german supplier at slightly bigger price (30 vs 25 EUR) but:
- lower CE saturation voltage - 2.4 vs 2.85V - lower conduction losses
- Ton - .32 vs .75 us
- Toff - .41 vs .65 us - lower switching losses
- reverse recovery time .35 us for both of them - important if using one as freewheeling diode
What's your opinion on using 2 modules (one as FWD) in ~500A 144-192V power section? Switching frequency at 8 kHz is probably the key; using 15V driver supply wouldn't hurt, either. Any extra mods suggested?
Regards
Mike
Old 01-28-2012, 12:39 AM   #2 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
I think it would be good.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
The Following User Says Thank You to MPaulHolmes For This Useful Post:
z_power (01-29-2012)
Old 01-28-2012, 02:34 PM   #3 (permalink)
jackbauer's Avatar
I actually used two fuji 1MBI800U4B-120 parts. One as switch and one as diode. Even driven from just a single rail 12v it worked well.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
www.evcbr.com
The Following User Says Thank You to jackbauer For This Useful Post:
Old 01-29-2012, 06:39 PM   #4 (permalink)
Thanks Paul and Damien; hope I'll soon make some progress worth posting here. For now I'm finishing logic board, maybe I'll be able to test it tommorow with simple mosfet/diode power section driving resistive load (12V bulb for first run...)
