12-22-2017, 03:16 PM
From non hybrid SUV to Volvo V60 D6 twin engine AWD plug in hybrid
Today i picked my new car up.
It is an second hand car. 4 years old. Only 85000km. Find out that the car had only 5000km done in electric.
This is my new thread of my new car. Here you will read all the news of my car.
It is charging at the moment. (20km range).
How do you fill in the garage? Only the fosile fuel? Or every charge in kWh converteer?
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011 + 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
The Following 4 Users Say Thank You to TimV For This Useful Post:
12-22-2017, 06:07 PM
My opinion - every time you charge, post kw-h in, distance traveled. The 'tank' is small ...
For a hybrid, I would expect you would charge every time you are near a 120V socket.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
12-22-2017, 10:41 PM
I must confess I'm quite curious to see what MPGe you'll get while driving on EV mode.
12-23-2017, 03:09 AM
Hete it is charging at 240V. At maximum selected power is it 3,5 to 4hours. Range should be 50km. Real range is 40 to 45km. (Tested)
I can drift
12-23-2017, 03:01 PM
Volvo-driving MachYeen
quite nice. And by training how you drive, you can probably even increase the mileage from there on pure EV
i've also considered a plug-in volvo in the future, i really like the new series Volvos. Theres a T8 XC90 parked every day at the hospital, and it looks really saxy :3
rolleyes: or maybe i'll convert a old 700/900-series into a hybrid if i become tech-savvy enough
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
12-23-2017, 03:51 PM
Right now i drive with winter tires. So higher rolling resistance.
I can drift
12-24-2017, 02:48 PM
Even though I've never been too overwhelmed about hybrids, except when I was 9 or 10 and became interested in the Prius for a , the XC90 T8 looks great.
I must confess, when I saw a XC90 T8 for the first time I started wondering what its drivetrain could do in a GMT400 Chevy Tahoe
12-24-2017, 10:44 PM
I've found most Nokians have pretty good rolling resistance, for what it's worth.
12-25-2017, 05:53 AM
#9 (permalink)
The first tracked rit is uploaded!
23.6km with 4,7kWh charge cost (electricity tooked from the net)
105mpg! (130 rated  )
I must confess, i had head wind.
I can drift
01-02-2018, 11:29 AM
#10 (permalink)
Filled the car up in this new year, and i will keep track of every charge i do, so i have nice data of the consumption i have with the volvo.
Diesel consumed: 22,71liters
Distance traveld: 805,5km
Diesel comsumption: 2,82l/100km
Dashboard indicated was 1,8km/100km
I know there is an diesel heat burner to heat up the engine and give heat to the cabin when driving in electric mode, but if that uses 1liter every 100km, then that sucks real hard...
I do not preheat the car nor have the temp running high.
If i turn of that diesel burner, then the car forces once and a while the diesel engine on, to get it up temperature...
Still needs to learn how to drive it more economical.
Estimated electricity used: 94,9kWh
Total consumption 322kWh (1liter diesel =10kWh)
Converted
= 399,75wh/km ?
= 3,9975l/100km?
Is this correct?
Edit: I found in the owners manual that when you use the additional heater (diesel burner) that the average fuel consumption is not accurate (is only the consumption of the diesel engine).
I can drift
Reason: additional info
