Old 10-24-2017, 02:59 PM   #1 (permalink)
Mpguino use with mechanical diesel
Hi all
As far as I can tell, the only issue with being able to generate a "fuel use" pulse is the lack of available flow meters at reasonable prices.
There are a a few marine sensors that have the required flow rates for my kubota d722 in my motorbike but they aren't that cheap.
If another arduino or a dedicated circuit can be used to deduct return flow pulses and then feed it real-time into the mpguino, this should work right?
Thanks all!
Old 10-25-2017, 09:32 PM   #2 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
The trick I've been running into is a sensor that runs slow enough for our flow rates..
This one was originally listed as low enough for our use with accuracy the control box would be extraneous.
Look at this on eBay http://www.ebay.com/itm/221972052943
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 10-26-2017, 12:39 AM   #3 (permalink)
https://www.wmjmarine.com/c56231.html
Ignoring the price, this one seems to meet the right specifications.
In additoin, one could reroute the fuel system so that a return sensor is not required.
If you route the return flow back to the inlet flow after the sensor, then the sensor will see all the fuel:
