Old 03-19-2008, 07:52 PM   #1 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Optimum piston speed?
I don't recall where, but someone once provided a link to an engineering text that mentioned 1000-1200 ft/mn as optimal piston speed for economy.
My question is, is that true and why is it?
Why wouldn't, say, 700-840 ft/mn be even better?
Old 03-19-2008, 08:55 PM   #2 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
I recall the same. At the time, I did the calcs for my engine and came up with the same RPM at which my best, constant FE is supposed to occur, which it, indeed, does:
1714 RPM @ 42.5 MPH (4th gear, Full TC lockup)
Here is a link to an article on it.
The text may hold some advice on the slower speed question.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 03-19-2008, 09:45 PM   #3 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Did you suggest that specific range for a reason?
Old 03-19-2008, 10:30 PM   #4 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
is there a calculator to determine the best speed for fuel economy? if so let me at it!
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 03-19-2008, 11:09 PM   #5 (permalink)
Here you go;
As a rule of thumb, most engines achieve their best fuel economy at an RPM corresponding to a piston speed of 5 to 6 m/s (16.4 to 19.8 ft/s). Piston speed (ft/s)= 2*stroke(inches)*rpm/720.
OR:
Piston speed = 2 x Stroke in inches x rpm / 720
Please keep in mind this is only a rule of thumb and specific situations will alter the "rule".
That said it is a good starting point.
The source by the way is Taylor as linked above.
A good book too since it has all the necessary info in one place and is more up to date than many others including Judd and the now classic Ricardo publications.
Cheers , Pete.
Old 03-19-2008, 11:30 PM   #6 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
I picked 700 ft/mn out of thin air, and went with a range of 20% as in the 1000-1200.
Old 03-20-2008, 12:05 AM   #7 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
It's a figure relating displacement to engine speed such that for relatively (+/-10%) square engines efficiency is pretty good.
Old 03-20-2008, 02:56 AM   #8 (permalink)
The text linked also has the volume 1 (under 'other editions') with nearly the whole discussion on efficiency. It centers on the efficiency graphs of piston speed vs mean effective pressure. They seem to orbit around the highest efficiency point, but mainly on MEP, not piston speed. So MEP is the key more than speed. At low MEP, lower speeds seem to hurt efficiency.
The Sulzer RTA96C that showed up as the 'most powerful diesel engine' is also quite efficient. It's rated at 92 to 102 rpm, with a 2.5 m stroke, listed 8.5 m/s (1670 ft/min) piston speed but it must be average speed. The highest efficiency is the high speed, lowest horsepower rating. Cross heads don't have much in the way of side pressure problems, but surely they don't have bore size or weight limits either. They must have chosen high piston speeds for efficiency.
Old 03-21-2008, 12:27 AM   #9 (permalink)
I would think that as slow as possible piston speed would yield the highest efficiency. After pondering it for a while maybe this ideal piston speed is best used to determine the bore to stroke ratio. After all if your piston speed is below what they consider optimum, you coulda designed you motor with more stroke and less bore for the same displacement.
Old 03-21-2008, 03:44 PM   #10 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
I wonder why an optimum rpm exists? The only things I can think of are:
Increased Inertial Loads at High Rpm?
Increased Friction at High Rpm?
Varying Disparity Between Piston Speed and Flame Front?
*(I know this set a limit on piston size during WWII @ ~5.5" Bore + Stroke)
Piston Position @ Peak Pressure?
Vibration?
Combustion Gas Dwell Time in Piston
Little Magic Elves Need Time to Do Their Work
Answers are no fun without the reasons.
- LostCause
News: Utah Considers Joining 80 MPH Speed Limit Club MetroMPG General Efficiency Discussion 68 11-04-2009 07:25 PM
News: Switzerland cutting speed limits to reduce emissions MetroMPG General Efficiency Discussion 7 09-18-2008 12:02 PM
Field Weakening Experiment for Speed Increase TomEV Fossil Fuel Free 12 04-10-2008 03:53 PM
Series Motor - Speed vs Torque TomEV Fossil Fuel Free 3 03-02-2008 12:27 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
