Old 01-30-2011, 11:04 AM   #1 (permalink)
SVTwithMPG's Avatar
El Diablo - '03 Mustang Cobra
Crapolier - '98 Cavalier base
90 day: 34.81 mpg (US)
Picked up a solid 4mpg. 98 Cavalier 3 speed.
I'm loving this website. I was getting about 24.5 mpg with my Cavalier. I read through the hypermiling tips and began to use some of them around half a tank. I don't shut my car off but I do let it coast in neutral when I can. I've done a little p&g. I try to conserve as much momentum as possible, but I'm still learning distancing. I read one member say that the highest speed they've applied their brakes at lately has been 18 mph, that is skillful. I drive alot of 50-55 mph roads with many traffic lights, some on timers, it makes it tough. This has quickly become a fun game to do while driving.
I filled up last night and came to 28.6 mpg I'm excited, driving through a whole tank should put me up to about 32. I also just checked my tire pressure today, I'm 24-26 psi all around. Yikes. I'm going to bump it up to about 46 today.
I'm running Sunoco fuel.
Old 01-30-2011, 09:07 PM   #2 (permalink)
Dub - '94 Golf Sport
Last 3: 31.07 mpg (US)
yah, that tire pressure is holding you back for sure, if you can, also try getting an ecomodder alignment
after that you should be around 35
The Following User Says Thank You to glhman222 For This Useful Post:
SVTwithMPG (02-09-2011)
Old 01-30-2011, 10:01 PM   #3 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle - '01 Echo Sedan
90 day: 42.53 mpg (US)
Pardon my ignorance, but what do you mean by "ecomodder alignment".
Old 01-31-2011, 05:53 AM   #4 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Setting the wheel alignment to be as straight as possible.
The more toe-in or out, the more drag is caused by the tyres not rolling straight on the road but being slightly skewed.
Lifetime fuel consumption :
Old 01-31-2011, 07:36 AM   #5 (permalink)
bhazard's Avatar
The TC - '88 Thunderbird Turbo Coupe
90 day: 28.03 mpg (US)
They still used a 3 speed in 98? Did it at least have lockup?
BP+T/G5MR swapped '93 Festiva
Escort GT Block, Garrett T3 50trim, A/R .42/.48
SRT-4 Intercooler
---Bests with BP+T---
1/4 mile ET - 12.99
1/4 mile MPH - 109.8
Best MPG - 36.8
Average MPG - 31 (over 11,500 miles)
Old 01-31-2011, 11:20 AM   #6 (permalink)
SVTwithMPG's Avatar
TH 125. It does have lock up. I was thinking about the alignment. Once I hit a wall I'm going to use HP Tuners to write a leaner tune with a lower idle.
Old 02-08-2011, 11:55 PM   #7 (permalink)
SVTwithMPG's Avatar
I'm pretty excited guys, I'm 435 miles into my tank of gas and my gauge is only at the 1/4 mark! Prior to finding this site I was getting about 340 miles to a full tank of gas. If I can get 500 miles by the time I hit the E then I got 35 mpg. 400 of my miles were with the extra weight of a passenger and luggage. I might throw a gas can in the trunk and just run it until it dies to see just how many miles I can go. This may be the first time I've looked forward to filling up.
Also, epa combined is only 23 mpg for my car.
Old 02-09-2011, 09:52 AM   #8 (permalink)
SVTwithMPG's Avatar
Originally Posted by NateHale88 View Post
I don't suggest running it out of gas due to the fact that sediment from the bottom of the tank will clog your fuel filter and that's not fun haha.. I couldn't imagine only getting in the 20s in a 4cyl lol. I have to beat on my v6 Grand Am to get 24. Good luck!
I thought not having overdrive was killing the mileage but the epa rating for the 2.2 with 4 speed auto was still a average of 23, and only 1 mpg higher for highway. It's just a poorly engineered car. The drag coef. is .36. I also believe the factory tune is on the rich side.
Old 02-09-2011, 08:51 PM   #9 (permalink)
SVTwithMPG's Avatar
34.8 mpg Just came back from my usual pump at Sunoco. I really would like to break 40mpg, time for more mods.
Old 07-07-2011, 02:09 AM   #10 (permalink)
crossout's Avatar
try driving at 50 mph... i have hit 42 mpg for almost 150 miles it was awesome!!! mine is a 3 speed auto and a 00 cavalier
2000 base cavalier 2.2 3 speed auto 4 door at 211,000 miles avg 26-28 city avg 30-38 high way highest mpg ever was 42 mpg for 125 miles at 50 mph...
